Arrand boring heads.
Home › Forums › Workshop Tools and Tooling › Arrand boring heads.
  • #410931
    Andrew Tinsley
      @andrewtinsley63637
      Does anyone know if Arrand boring heads have replaceable arbours? If so does anyone know if they have a common thread?
      Andrew.
      #19351
      Andrew Tinsley
        @andrewtinsley63637
        #410941
        Brian Wood
          @brianwood45127
          Hello Andrew,
          Yes, they do. The thread is 16 mm x 1.5 right hand
          Brian
          #410956
          Andrew Tinsley
            @andrewtinsley63637
            Thanks very much Brian! I thought someone would know.
            Andrew.
            #410958
            SteveI
              @stevei
              Hi,
              the 3” head uses M14x1
              the 4.5” and 5.25” use 16mm x 1.5mm, the shanks are the same as their fly cutters.
              the 6” I don’t know.
              the 6.5”, 8” boring and facing and 10.5” all use the same shanks but these are held on by a register and 4 shcs.
              steve
              #410960
              ronan walsh
                @ronanwalsh98054
                Are Arrand boring heads still made ? I was looking for one last year and wanted an arrand, could not see much online about them. Bought an American made head instead and its good. Most of the asian made heads i have used seem to use a mystery measuring system on the dial.
                #410961
                Andrew Tinsley
                  @andrewtinsley63637
                  Thanks Steve, I might have expected that it was more complicated!
                  Andrew.
                  #410962
                    Posted by ronan walsh on 25/05/2019 22:00:36:
                    I recall that it was essentially a one-man operation. He tried to sell the business when he retired but I don't think it continued. I may be wrong.
                      It may be worth trying a 'phone call
                      see this thread: **LINK**
                      https://www.model-engineer.co.uk/forums/postings.asp?th=94955
                      Brian Wood
                        @brianwood45127
                        Hello Andrew and Steve,
                        Just to complete the list, my boring head is 3.25 inches and the arbour on that is interchangeable with that of the fly cutter bought at the same time.
                        Thank you Michael G for snuffing out a hopefully live phone number to this excellent company, I am another fully satisfied user for >25 years
                        Brian
                        #411028
                        SteveI
                          @stevei
                          Hi,
                          I should have been clear about the sizes; those are the names that Arrand gave the different models. Based around the maximum bore using a side tool. From the catalogue the outside diameters of the heads are:
                          the 3” head 1.3/8” or 35mm
                          the 4.5” 1.3/4” or 44mm
                          The 5.25” 2.1/8” or 54mm
                          the 6” 2.1/2” or 63mm
                          the 6.5” 2.3/4” or 70mm
                          8” boring and facing 3.1/2” or 89mm
                          10.5” 4” or 102mm
                          The catalogue I have does not mention a 3.25” head.
                          AFAIK Arrand does not manufacture any more but still trades selling from stock. I purchased my 3” head a few weeks ago direct from Arrand.I think rotagrip have some of the heads in stock according to their website.
                          steve
                          #620939
                          Colin Heseltine
                            @colinheseltine48622
                            Today I visited the Clock Fair at Midland Motorcycle Museum. Whilst there I managed to pick up a brand new, still in the box, Arrand 4 1/2" boring head. It is not fitted with an arbor. I am trying to work out what thread it is. This post implies they are M16x1.5. This one certainly is not. The box is marked Imp (I guess for Imperial) and I assume this is for the graduation scale. It would appear to be 5/8" but not sure what TPI.
                            Does anyone have any other ideas. I would like to fit it to an R8 arbor for use on the big mill.
                            Thanks,
                            Colin
                            #620941
                              What makes you feel it is 5/8" rather than 16mm as there is 0nly 0.1mm difference between the two which would be hard to measure.
                              #620942
                              Colin Heseltine
                                Cannot get a M16 x 1.5 tap to thread in. It struggles to fit into the spigot bore.
                                #620943
                                DC31k
                                  @dc31k
                                  Posted by Colin Heseltine on 13/11/2022 18:45:34:
                                  Screw a 5/8 dia. piece of wooden dowel into it. The threads will imprint on the wood and then you can measure pitch or tpi with a thread gauge.
                                  #620945
                                  Colin Heseltine
                                    Just had another play with it. Managed to find a new No.2 Second M16x1.5 tap and this did eventually thread in. There is a tommy bar hole and also a small threaded hole which both break into the thread before the thread has completed two turns. The bottom tap I had tried did not want to go past this point. I was being too gently. The number 2 tap has left a good witness mark in the spigot bore but got past the break in points and then threaded in nicely.
                                    Just need to put M16x1.5 thread on an R8 arbor now.
                                    Colin
                                    #620948
                                    Colin Heseltine
                                      DC31k,
                                      That's an idea I'd not thought of. Must remember for future.
                                      Colin
                                      #620949
                                        ARC sell them if you don't want to make one
                                        #620951
                                        Colin Heseltine
                                          Jason,
                                          Thanks for that. At £9.58 plus postage its not worth switching the lathe on. One arbor just ordered.
                                          Thank you,
                                          #621076
                                          Halton Tank
                                            @haltontank
                                            Arrand Boring heeads are available at Rotagrip (at least their website says so). See Rotagrip Boring Heads
                                            Regards Luigi
