Weiler Matador owners. Suggestions needed
Home Forums Workshop Tools and Tooling Weiler Matador owners. Suggestions needed
  • #371874
    JouniP
      @jounip
      Hello
      I have German Weiler Matador lathe. It had small gearbox fault, some small screws loosened, dropped and jammed gearbox lever. I had to remove gearbox but I did not need to break up the gearbox. Before I could remove gearbox I have to remove covers, Apron and lead screw. I also had to remove gears, pulley and belt seen on following Youtube video.
      Now I am not sure if I managed to assemble lathe correctly again. Lever I use on video (lower and left one) should change transmission between belt and gears. But does it work as it should?
      Are there any Weiler Matador owners? Does Your Matador act like mine?
      Jouni
      Link to video
      Edited By Neil Wyatt on 16/09/2018 15:18:49
      #19074
      JouniP
        @jounip
        #371948
        Brian H
          @brianh50089
          Hello Jouni, I see that no one has replied yet so this should bump it up to the top.
          Brian
          #371981
          Brian H
            @brianh50089
            Hello again Jouni, I came across this site.
            http://www.lathes.co.uk/weilermatador/
            Brian
