Recommend T handle metric key set
Home › Forums › Workshop Tools and Tooling › Recommend T handle metric key set
Viewing 25 posts - 1 through 25 (of 59 total)
  • #339237
    petro1head
      @petro1head
      Sick of cheap Thaddeus hex sets. The ball end ones break and the straight ones are never the correct size especially the small ones that need to be files down to fit.
      So what a good make to buy?
      #18832
      petro1head
        @petro1head
        #339238
        Vic
          @vic
          Bondhus make arguably the best hex keys. They supply NASA.
          I use their T handle ball drivers and never had a problem with them.
          #339239
          Paul Barter
            @paulbarter66156
            Bondhus are indeed excellent, I have a metric set, but my ball ended "expert" .Draper set obtained from my local branch of Allparts is every bit as good at half the price. Where do they hide?
            regards Paul
            #339240
            Muzzer
              @muzzer
              #339241
              petro1head
                @petro1head
                Thanks. Found a set here **LINK**
                Edited By petro1head on 31/01/2018 22:20:42
                #339244
                Bill Mull
                  @billmull
                  Facom or Garant make very good T handle sets
                  #339250
                  Mike Poole
                    @mikepoole82104
                    Eklind make a decent set of T handle Allen keys. Bondhus are my preferred supplier, get the metric set with all the odd sizes like 7,9,5.5 and other odd sizes. Used the 7 on Audi brake caliper pins yesterday. Haven't found a use yet for some of the odd sizes but armed and ready when they do turn up. Don't you just hate having to grind Allen keys to fit the non preferred sizes?
                    #339252
                    ega
                      @ega
                      I think that under the skin most T handled Allen wrenches are L-shaped. I have a few vintage wrenches with a genuine all-steel T form which are good for heavier work.
                      Needless to say, if the wrench is too tight for its proper screw the screw won't mind you using a suitable wrong size wrench.
                      Equally obvious, a good grinding rest makes reducing an oversize wrench relatively straightforward; I must try filing one some time.
                      #339258
                      Enough!
                        @enough
                        Posted by ega on 01/02/2018 00:02:10:
                        Something else that can be very handy on occasion is a long, plain Allen key (just the straight part, no L, no T). They are made, if you can find them. You can drive them from a socket wrench and if you have a screw that's buried deeply in a recess where you don't have room to swing a cat (or a bent wrench) it can be a life-saver. (There's one in the head of the ML7 that's like that).
                        #339262
                        Involute Curve
                          @involutecurve
                          Bondhus, you cant break em, had a set for years one of my best ever tools
                          #339263
                            I also like the Eklind tee ones, proper metal tee not a plastic moulding on a L shape.
                            If you are filing down ends are you mixing metric keys and imperial fixing
                            #339265
                            Billy Bean
                              @billybean67480
                              Bondhus.
                              #339266
                                I want a set of hex screwdrivers!
                                #339267
                                petro1head
                                  @petro1head
                                  Posted by JasonB on 01/02/2018 07:30:23:
                                  Not the case Jason. When I measure further up the shaft (Say the 3mm one) its somit like 2.95, however at the end it more like 3.14 and these are new. However they we cheap Silverline ones from eBay
                                  #339270
                                  petro1head
                                    @petro1head
                                    Has anyone heard or Beargrip (Made in Holland). I have a couple of these that I was given and they fit fine?
                                    #339273
                                    petro1head
                                      @petro1head
                                      Posted by Neil Wyatt on 01/02/2018 08:22:43:
                                      You can have mine
                                      #339275
                                        ‘However they we cheap Silverline ones from eBay”
                                        So, not very surprising. I reckon those are cheaper rubbish than Rolson used to be 20 years ago! Use once and throw away, unless it is simply threading in and out without any serious tightening or loosening. In fact, likely not get to using them once on really tight fixings – they can easily either strip, due to improper fit, or bend.
                                        I bought a Deltec branded set from HIS, last time we were in Inverness. Not used much and I don't try to undo any tight cap screws with a ball end. I use my Stanley or CK for the tough jobs, so they have not been unduly stressed.
                                        The Deltec ones were cheap as there are both hex and torx in the one box. Just a useful set hanging on the wall. Bought because I was impressed with a set bought from HIS and used for motor repairs, by my step SiL.. His were red, my set are yellow, so I am not yet sure if they are comparable on quality.
                                        #339277
                                        Tony Pratt 1
                                          @tonypratt1
                                          As always 'buy cheap, buy twice' ! I know someone will now disagree.
                                          Tony
                                          #339288
                                          Mike Poole
                                            @mikepoole82104
                                            The market seems to have been flooded with cheap socket screws. The fit of the socket is poor even with good keys.the fit of an Unbrako hex key in an Unbrako socket is excellent, no slop at all even makes a pop if pulled out quickly. Beautifully formed threads as well.
                                            #339292
                                              I use the Bondhus ball ended ones, Model Fixings do them
                                              #339293
                                              petro1head
                                                @petro1head
                                                Posted by Mike Poole on 01/02/2018 09:50:07:
                                                Agrees, a lot of cheap toffee screws around mainly from China. The bolt that camps my vice was Chineese and the threads stripped within 1 month
                                                "Buy Cheap Buy Twice" I should know better
                                                #339294
                                                Muzzer
                                                  @muzzer
                                                  The original Allen keys used to have some form of guarantee eg they would always twist (deform) by half a turn before they finally failed. They don't seem to claim that nowadays. here is a company that claims to be the original Allen company but I wouldn't be surprised to discover that the name was bought by a trading company and is badged onto Far Eastern products, as is the fashion these days. With a token production site in the US obviously, so they can claim "made in USA" etc.
                                                  I've got a set of Wiha ball-ended hex screwdrivers, actually bought individually. I think these are mid-range in terms of quality. Forget where I bought them. If you get the "screwdriver" style, they might as well be ball ended, as you are limited in the torque you can apply.
                                                  Big selection of hex drivers at Screwfix including Bahco (Sandvik), Teng Tools etc. I need a set of the tee handled ones. These often have a ball on the "long" end and a straight hex on the "short end".
                                                  Murray
                                                  #339296
                                                  Michael Briggs
                                                    @michaelbriggs82422
                                                    What is the range of sizes you are looking for.
                                                    #339301
                                                    Vic
                                                      @vic
                                                      The good thing about the Bondhus T handle hex keys are that they have proper welded T handles unlike some other brands. The T handle is also heavy enough to provide a flywheel effect enabling you to “spin” fasteners in quickly.
                                                      The ball ended ones are great on machines with limited access to lock screws etc.
