Perfectly ground Twist Drills every time.
Home › Forums › Workshop Tools and Tooling › Perfectly ground Twist Drills every time.
Viewing 25 posts - 1 through 25 (of 209 total)
  • #17384
    Former Member2
      @formermember2
      #151267
        Nice Work, Gray !!
        I propose a big vote of thanks
        Clive Foster
          @clivefoster55965
          Well done Graham.
          Nice to have practical demonstration that the major conceptual weakness in the inexpensive commercial version is the fixed eccentricity imposed by simply bolting the drill carrier Vee onto the side of the pivot rod assembly with a fixed offset from centre. Its a shame that most of the people making / supplying these devices clearly don't understand what they are making.
          I like the improved drill clamp arrangements. Much better than the usual but have you considered the possibility of arranging things so that the whole drill carrier part can be inverted on the pivot unit so the drill only has to be mounted in the carrier once. That way if you do make an error of projection both sides will be the same and the drill will still cut fine. Exact angles aren't super critical, obviously or the commercial rubbish would never work, but identical grinds each side are important. A separate carrier could also make it easier to measure and set projection. Athough it adds parts two carriers, for small and large drills, might well be easier to use. Thats the way I'm going, well actually 3 carriers, should my four facet sharpener ever make it from the back of the envelope into metal along with the rest of "Clives Improved Tool Sharpening System."
          The vertical pivot and 5 to 5 drill orientation used in the Picador system is much less sensitive to offset / eccentricity because it needs less correction in absolute terms but orientation is much harder. Especially as the projection has to be derived automatically from the orientation rather than having an measured absolute fraction of diameter value.
          No doubt that the American Delta 1296 / Atlas 2195 aka W30 ones are the best of the home shop breeds.
          Edited By Clive Foster on 02/05/2014 18:46:27
          #151274
          NJH
            @njh
            Well done Gray
            That encourages me to dig my jig out from the " must try it again … sometime" heap.
            ( I imagine that all your drills are in pretty good order any way ……… so if you would like a few (dozen) to "prove" your modification I'm sure that I could " lend" you some! )
            Norman
            #151276
            Thor 🇳🇴
              @thor
              Hi Gray,
              as usual very nice work, and thanks for the advice on improving the jig. I have a similar drill grinding jig myself, so when I finally finish the screwcutting clutch, the jig will become my next project.
              Thor
              #151281
              John Haine
                @johnhaine32865
                Nice work! Where did the basic jig come from please? Would be nice to see an article on this!
                john
                #151286
                Ady1
                  @ady1
                  The 1951 article is by Duplex and runs to quite a few issues
                  "Making a Twist Drill Grinding Jig"
                  ME no 2632 2634 2636 2638 2640 2642 and 2644
                  #151290
                    Looks like new life has been given to 100 old jigs, including mine if I can find it.
                    My recollection is that the joint with the wing nut was very sloppy on mine and I had planned a cross brace to 'complete the triangle'.
                    John, they can be found from a google search for 'drill grinding attachment' or going to a carboot / garage / yard sale. they used to be quite difficult to sell to model engineers who knwew their reputation but I supect that will now change.
                    #151301
                    NJH
                      @njh
                      Hi Gray
                      "As regards an article I had thought about writing it up but I fear my work is no longer in vogue these days."
                      NOT IN VOGUE!!!!!!
                      I think this would be an excellent article and would encourage workshops full of sharp drills across the world!
                      I guarantee that I will buy any publication carrying such information.
                      Who are these arbiters of taste and value? – let us know so that we all may shout at them.
                      Norman
                      #151305
                      Oompa Lumpa
                        @oompalumpa34302
                        Posted by NJH on 03/05/2014 10:28:48:
                        Hi Gray
                        NOT IN VOGUE!!!!!!
                        Who are these arbiters of taste and value? – let us know so that we all may shoot at them.
                        Norman
                        corrected that for you Norman.
                        graham.
                        #151306
                        MM57
                          @mm57
                          Oh dear.
                          https://www.youtube.com/watch?v=cqn2VPGYA9c
                          mrpete222/"tubalcain"
                          4m 57s onwards…
                          Edited By Martin Millener on 03/05/2014 10:57:28
                          #151316
                          John Stevenson 1
                            @johnstevenson1
                            I'm fortunate that I can sharpen drills by hand but in all fairness I have had a lot of practise, often having to spend possibly an hour a day sharpening drills, most under 3/16"
                            Re reading that previous sentence I think the critical word is practice but it's something we don all get chance to do. For a start we probably don't own enough drills to get this practice in.
                            I have noticed that before and after that job I had occasionally I 'lost' the knack of getting the right wrist action.
                            I have one of these early copies, possibly Taiwanese because of it's age, it's certainly not a genuine Reliance and to be honest I have found it to work OK but slow and fiddly. What I have found though is that if when the 'knack' goes, it's dragged out of retirement and a couple of drills are resharpened with the jig it 're teaches' you the 'knack' or at least it does for me.
                            So mine whilst spending 99.8% of it's time in a drawer is still a very useful tool.
                            The next bit might get boring but does contain some useful info.
                            As well as running the boring shop at a piano company where and don't scoff we had to drill tens of thousands of holes in wood per day to a tolerance of half a thou I also had the design and build the machines to do it. After leaving there I started making division plates as a sideline and don't ask me where they all go but I'm still making the same amount today as I started out doing. Some of the special sets have over 800 holes in them and at a push I can do 10 sets a day so I have probably learn more about small drill than anyone else on this forum.
                            What I have learnt is than no 'commercially' made drills out there can drill an accurate hole repeatedly and make doesn't come into it. What I have learnt is that none of what I call the commercial spiral swept point drills as shown in the photo's above will repeatedly drill accurate holes.
                            Note the word repeatedly and this isn't a dig at Graham, he didn't invent the shape.
                            What happens is that because the centre of the web spins at zero revs being on the centre it rubs and eventually breaks down into small flats or craters, I have stage by stage microscopic photos to prove all this. Subsequently it then starts to pivot away from the centre to find an edge that does cut but is then off position.
                            It takes a while to do this and anyone only drilling a few holes and keeps their drills sharp will never come across this, we are talking worse case scenario or shed man as opposed to engineer man wink
                            This is where 4 facet drills come into action and a correctly ground 4 facet drill can extend the life of a drill by a factor of 4 or 5 but most importantly it also extends it's accuracy by he same amount.
                            Later I'll sort some photos out of a 3.0 mm drill after drilling 800 holes and its 4 facet brother at the same stage of life. the commercial drill is frankly well past it's useful like and has been for a while but the 4 fact drill can go on to do up to 24,000 to 30,000 holes.
                            It's not just about replacing a cheap throw away drill, it's about accuracy and life. A drill grinder for doing these small drills in the after-market scene costs around £12,000, not a typo. they still make them and still sell them so it proves there is a demand for them.
                            Now then, is it necessary ? perhaps not in a home shop but we can learn from this. Lets face it this forum has a greater percentage of armchair machinists prepared to argue the last micron than probably any other.
                            #151322
                            John Stevenson 1
                              @johnstevenson1
                              Graham,
                              I think you have done an admirable job and have no problems with the way you have identified and rectified the problems and I am 100% behind you.
                              I just wanted to point out the short comings of the commercially and read cheap process of the common drill geometry and how it fails.
                              However I am amazed by your statement " Hole accuracy was not the underlying criteria, grinding the correct angle, with the generally accepted 12 degree relief and a chisel angle of 110 to 115 degrees as recommended by Osborn or Dormer drills was, and I am please to say I have achieved this at minimal cost."
                              To me hole accuracy and it's placing take preference over what anyone, Osborn or Dormer say about angles.
                              Modern technology has proved time and again what we were taught by rote and everyone since has repeated parrot fashion is not always the correct way.
                              Currently one of the most accurate and precise ways of producing holes is with inserted cutter spade drills which have a geometry nothing like Osborn or Dormer dreamed up.
                              A Derby company is currently making the test centres for Mitutoyo, basically two tailstocks facing each other on a common bed. It's a simple operation for what is a precise operation, the tailstock with ground base is placed in a jig of a machining centre and a 30mm diameter spade drill is fed in. No pilot, no cored hole just straight thru.
                              No drilling, boring or reaming, just one operation the get a finished hole repeatedly to a tolerance we can only dream of. Mr Myford would be turning in his grave [ pun intended ]
                              Edited By John Stevenson on 03/05/2014 15:10:34
                              #151324
                                Posted by John Stevenson on 03/05/2014 13:46:06
                                … we had to drill tens of thousands of holes in wood per day to a tolerance of half a thou
                                John,
                                These are absolutely genuine questions, so please don't ridicule me for asking:
                                • What do you actually mean by that statement? [position/diameter/circularity, etc.]
                                • How did you achieve it?
                                • How was the work inspected?
                                I can see that it's reasonable enough to position the machine head, and the clamping fixture, to half a thou in X-Y … but every other aspect of working to such a tolerance in wood leaves me bewildered.
                                John Stevenson 1
                                  @johnstevenson1
                                  Michael,
                                  No it's a perfectly reasonable assumption to doubt this. To be honest when I first went there I thought it was a wind up and it took a couple of days on the shop floor for it to sink in that they were serious.
                                  First off the wood was seasoned beech, maple or hornbeam, we are not talking about old window frames here so very stable. Moisture content was 11% and our own kilns which could handle artic loads could work to plus or minus 1 percent.
                                  Machines were automatic feed cam driven and placed the part into steel vices also clamped by cams. Many of the parts has up to 5 holes in them. Many were bored thru the vices and they would have clearance holes which were then brazed up and redrilled to act as drill bushes or wooden plugs of lignum vite.
                                  Drills were usually held in special high speed spindles running at 200 Hz for 12,000 revs or 400 Hz for 24,000 revs.
                                  Similar the the high speed spindles sold by ARC but these were German Persche <sp> spindles and cost about 1K each, had a working life of 2 years before needing to be reconned.
                                  The shop had 3 ring mains, conventional 440v 50 Hz, 220v 200 Hz and 240v 400 Hz, the latter for the high speed spindles and this power was supplied by two large motor generators at the bottom of the shop. We probably ran in excess of 40 high speed motors
                                  Drills were conventional high quality jobber drills, usually Guring, tanen out of their wrappings and measured then stacked by size. It was normal to get say 1.8mm drills to measure from 1.798 to 1.803mm out of the same packet. They were then ground into 3 point wing and spur drills. When I first went there this was done by hand on a range of grinders which were nothing more than a row of motors with wheels on both ends, no guards and no rests, everything was by eye. later we paid £12,000 for a Christian grinder will all the attachments which speeded the job up no end.
                                  When a drill broke or got blunt. it would be replaced with a new one and the fun would start. A few test pieces would be drilled and checked with go – no go pin gauges with 1/2 thou differences. If you were dead lucky they would get passed by a travelling inspector who did nothing but move from machine to machine taking pieces and testing on pins and gauges. If it was OK he'd sign the machine off.
                                  Usually it was too sloppy so you would try smaller drill from the same batch and even stone the edges with a stone that looked more like a mirror, probably a 100,000 grit. Often you could spend a good couple of hours getting the machine back on line before you moved onto one the inspector had closed off. We had two guys doing nothing but change drills and another guy doing nothing but sharpen drills tools knives and scissors.
                                  We made nothing but piano actions and keyboards for uprights and grands for all the major manufacturers, all they made in hose was the carcases. Steinway, Kemble, Kimble Bechstein, Baldin and Bosendorfer to name but a few of the more famous ones.
                                  We made all our own springs, hammers and all the felt components. Any moving part on an action ran on pins 0.0505" in diameter, a standard reached in the late 18th century but unfortunately a size no drills exist for. In the early days of the 20th century they made drills by filings tool steel wire down, hammering and filing into a spade bit then hardening. In my day we bought HSS drill blanks in exact size then hand ground these into spade drills.
                                  Every working hole was bushed with a felt bush made from a strip of felt glued on one size then formed into a 'U' then rolled up and pushed into the hole.
                                  A very hard process in fact the machines that did this were that secret they were in a locked room and the operators were sworn to secrecy.
                                  #151329
                                  Tony Pratt 1
                                    @tonypratt1
                                    Posted by John Stevenson on 03/05/2014 15:09:04:
                                    So how is the hole diameter controlled to a "tolerance we can only dream of" in this straight through operation?
                                    Tony
                                    #151330
                                    John Stevenson 1
                                      @johnstevenson1
                                      Purely by the insert that goes into the spade drill, which in this case is supplied by Mitutoyo to the company.
                                      When they were first approached to make these they were ready to turn the job down because of the specs.
                                      Being basically old school they questioned the tolerances and what was allowable. Mitutoyo looked basically confused and said try this and gave them the drill and when it worked out as it should they were amazed
                                      #151336
                                        Posted by John Stevenson on 03/05/2014 17:09:54:
                                        Michael,
                                        John,
                                        Thanks for the explanation … much appreciated.
                                        That "Good to Go" process reminds me of when I worked a Kodak in the mid '70s … They injection-moulded plastic lenses for the little cameras, and the machines took ages to get to exactly the right tmperature and pressure. The operator would run a batch of lenses, which were then checked against masters [to so many fringes]. I particularly remember the "early adoption" of video monitoring for this testing. … Once the machine was finally stable enough to produce good lenses, they would then run-off a batch of a thousand or more; before anything drifted.
                                        michael howarth 1
                                          @michaelhowarth1
                                          Graham…..PLEASE write up jig adaptation and method of use for thickheads like me.
                                          Neill……..PLEASE publish.
                                          Mick
                                          #151349
                                          Tony Jeffree
                                            @tonyjeffree56510
                                            YES please write it up for MEW – and then perhaps one of the suppliers will get these made properly over in China to help everyone out.
                                            Tony
                                            #151367
                                            Gordon W
                                              @gordonw
                                              Gray- If it is any help I remember something about the grinding best to be at 90 to the cutting edge. This was many years ago, may have been at tech., but seem to think it was was to reduce the stress fractures on the very edge. All I can remember I'm afraid.
                                              #151369
                                                Gray,
                                                Sorry, I can't point you to an authoritative reference; but your recollection seems entirely logical.
                                                At the microscopic level, even the best grinding marks are like the furrows in a field [first illustrated by Robert Hooke, in Micrographia] so, obviously, grooves parallel to the cutting edge will weaken it dramatically: At the opposite extreme therefore, grooves perpendicular to the edge will weaken it least, and every angle between these extremes will be intermediate in effect.
                                                Edited By Michael Gilligan on 04/05/2014 10:11:02
                                                #151376
                                                  Michael,
                                                  The cuttting edge of a twist drill isn't truly radial. Is the best angle at 90-degrees to the cutting edge or tangential to a circle at the point where it crosses the edge. And if the latter, at what point on the cutting edge? Half diameter? Half way along? Outer end? Inner end?
                                                  I expect a detailed finite element analysis of the forces on the cutting edge by 4:00pm
                                                  (If I know you lot someone WILL go and do this! – so here's a starting point: lisafea.com/)
                                                  Edited By Neil Wyatt on 04/05/2014 10:22:34
                                                  #151393
                                                  IanT
                                                    @iant
                                                    I believe it is mentioned here Graham
                                                    IanT
                                                    #151405
                                                    John Stevenson 1
                                                      @johnstevenson1
                                                      Never underestimate how grinding affects the outcome. I can see in Grays case why he's thinking about getting the marks at 90 degrees to the cutting edge.
                                                      My 4 facet grinder does that and it also has the facility to do it in either direction. It makes a big different, probably not so much on the cutting but more on the life of the tool.
                                                      Sorry to harp on about the piano company but because we were using all non standard tools and had been for over a 100 years there was a lot of experience on how to do the job and get the best out of the tools.
                                                      All the slotting saws were special widths. We tried having them commercially made but they were expensive and didn't last because like all commercial saws they were hollow ground and after the first couple of grinds they were under size.
                                                      If you just surface grind a saw to the correct width all it does is burn the wood because it has no clearance. The trick was to grind them a thou undersize then sharpen the teeth making sure the wheel ground off the cutting edge, not onto it. Every alternate tooth was ground one way and then either the saw was turned over or the grinder reversed to do the other teeth.
                                                      Basically the burr acted as clearance. Now you would think that burr would soon be worn away but truth was they lasted quite a time and a simple face grind and they would be good to go again.
                                                      We can prove the same thing in this world as well. Get a brazed tipped lathe tool and grind one face on a green grit wheel with the direction of grind going down the face and look at it under a decent glass. The edges will be all small craters because the carbide is so friable. Then reverse the operation and the edge damage is reduced considerably.
                                                      Same applies to HSS but because it's not so friable the results are not as obvious to the naked eye, but they are still there hence the advise to hone the edge afterwards.
