homemade nickel plating with coins
Home Forums Workshop Techniques homemade nickel plating with coins
  • #644770
    celso ari schlichting
      @celsoarischlichting85092
      In this video I used pure nickel coins to finish some mechanical parts.
      https://youtu.be/1qFb6Ijcqk0
      Greetings from Brazil
      Celso Ari
      #16441
        #644772
        Ady1
          @ady1
          Clever.
          #644948
          vintage engineer
            @vintageengineer
            UK coins are only 25% nickel and that is only on the surface.
            #644950
              Posted by vintage engineer on 12/05/2023 19:38:11:
              Reality check: **LINK**
              The Metals in UK Coins
              The change to plated steel coins did not include all denominations.
              20p pieces are a good source.
              Peter Cook 6
                @petercook6
                Section 10 of the 1971 Coinage Act makes doing this with UK coins illegal.
                #644957
                Dalboy
                  @dalboy
                  Posted by Peter Cook 6 on 12/05/2023 20:56:24:
                  Simple go to an exchange and buy Brazilian coins and use them
                  #644959
                    Quite right too yes
                    https://www.legislation.gov.uk/ukpga/1971/24/section/10
                    Can’t have people destroying money !
                    … I wonder what the correct antonym for ‘quantitative easing’ might be dont know
                    Edit: I should have quoted Peter’s post
                    Edited By Michael Gilligan on 12/05/2023 21:11:04
                    #644971
                      But isn't a bit of actual nickel sheet cheaper?
                      #645001
                      Russell Eberhardt
                        @russelleberhardt48058
                        Posted by Bazyle on 12/05/2023 22:08:58:
                        Yse, plenty on Ebay.
                        #645129
                        old mart
                          @oldmart
                          With practically any modern "silver" coin, the alloy will be one of the many cupro-nickels, so the platinc might be an alloy. If not, there would be a lot of copper contaminating the bath,so using the purest nickel available would be safest. Commercial nickel plating has the anodes in bags and continuous filtration is needed.
                          #645250
                            Just make sure you wear those gloves!
                            Nickel dermatitis causes all sorts of problems.
                              You can't " melt down or break up any metal coin " so presumably the machines which squash coins and emboss the name of a seaside town or other tourist attraction are still legal!
                              DMB
                                @dmb
                                Not only all new "Bronze" coins are steel and plated, so are some of the "silver" ones.These being the so called nickel type.
                                Emgee
                                  @emgee
                                  Not to hi-jack Celso thread but for a good undestanding of the nickel plating process I found the following Youtube video helpful.
                                  Emgee
                                  #645331
                                    Posted by Neil Wyatt on 15/05/2023 18:08:23:
                                    British law dates back to when the metal value of coins matched their face face value – a Florin contained 2/- worth of Silver. Thus, for both local and international trade, anyone's coinage was acceptable in exchange for goods.
                                    Unfortunately, people would hoard coins, causing trade to grind to a halt, clip metal off the edges, replace sections with base metal, replace real with fakes, and otherwise undermine the whole economy for personal gain. Another serious problem was that the value of Gold and Silver aren't stable, so if the scrap price of Gold rose above the face-value of the coinage, then coins would be melted down, bringing trade to a halt due to a shortage of money. The government would be required to mint more, buying metal in short supply that cost more than the value of the coin. Nasty.
                                    The first response was to make coins the property of the King or Government, their metal value being on loan, rather than owned outright by individuals. This made it possible to apply serious punishments to anyone who messed with the currency, up to and including the death penalty. Undermining the money system was in the same league as treason.
                                    Second response was to realise that as coins were now only tokens, their value assured by the state, there was no need for the metal to match the face value. And carrying the token idea forward, it was found far more convenient for money to be on paper – banknotes, bonds and shares, or even just in a ledger or in a telegram.
                                    As modern coins aren't central to trade any more, and are rarely worth the metal they're made of, the law is unlikely to be interested. Unless the abuse is on a large-scale. Minting your own money is still serious crime!
