How to rivet in straight lines?
Home › Forums › Workshop Techniques › How to rivet in straight lines?
  • #189438
    Malcolm Harvey
      @malcolmharvey97633
      I was wondering if anyone here has any advice on how to create a row of holes in a nice straight line for riveting. I have no problems with the actual act of riveting but getting a row of holes in a straight line is a different matter. I am using 1/16" snap head brass rivets. I have had much better results with larger rivets so I guess it is also a problem with the smaller size. I am doing Titfield Thunderbolt tender sides and back.
      TIA
      #15777
      Malcolm Harvey
        @malcolmharvey97633
        #189440
          If you have a mill then do your drilling on that using a spotting drill then 1/16" stub length drill.
          If only a drill press then clamp something to the table to act as a fence and do as above.
          Whats your marking out like? do you use an optical punch or normal? dot punch first or straight at it with a less accurate centre punch mark.
          These are all 1/16" mostly with the factory head inside, there is one in the back horixontal row thats a bit off to my eye.
          #189444
          Bob Brown 1
            @bobbrown1
            If you have access to a mill which has a DRO then you could make up a jig say 10 holes long and use that to position the holes moving it along as you drill the holes.
            Bob
            #189446
            Malcolm Harvey
              @malcolmharvey97633
              No mill (yet) unfortunately. I am centre punching with a punch that has a long narrow point. I have already found that with a 'normal' punch I can't see where the actual point is on the metal. I didn't know about optical punches – read about them and I want one!
              #189450
              IanT
                @iant
                Going back many years Malcolm – there was an idea in one of the railway modelling magazines – whereby the work to be riveted (brass sheet in this case) was clamped to the saddle of a small lathe – behind which the modeller had mounted a small drill. By using the lathe feed screw he was able to move the work under the drill by controlled amounts (e.g. one full turn = 1/8th" -so 1/4 turn equalled 1/32nd etc.) and get nicely spaced holes for his rivets.
                Never tried it myself but I remember thinking it might be a useful thing to know one day.
                IanT
                #189453
                Capstan Speaking
                  @capstanspeaking95294
                  Posted by Malcolm Harvey on 11/05/2015 13:41:55:
                  Tilt the punch 45 deg away from you. Place the point on the spot and pivot it upright. It can be done. Opticals require more elbow room on the surface.
                  #189463
                  Jesse Hancock 1
                    @jessehancock1
                    Jason: If I attempt a large scale model of the Titanic you can have the job of riveting her up. Nice job you made of that firebox, if that's what it's called.
                  Home › Forums › Workshop Techniques › Topics
