Mystery change wheels
Home Forums Manual machine tools Mystery change wheels
  • #443686
    Robert Bailey 1
      @robertbailey1
      I purchased a Harrison L5A 11 inch which came with these change wheels that are for another lathe. I would be grateful for help identifying what they fit so I can sell them and the proceeds go towards obtaining some of the right ones. There's a total of 6, 16DP at 100 % confidence, Teeth 55, 60, 65, 70, 75 and 100. 3/4 inch bore, 1/2 inch wide, 1/8 inch keyway. The cast ones have a L4 marking and what looks like 88 or 86 but could just be marks from the runner or raiser.img_20191224_122852_7.jpg
      #13738
      Robert Bailey 1
        @robertbailey1
        #443769
        Martin Connelly
          @martinconnelly55370
          Smart and Brown model M, possibly other models as well.
          Martin C
          #443779
          Robert Bailey 1
            @robertbailey1
            Thanks, There were some Smart and Brown threaded catch plates included to.
            #443783
            old mart
              @oldmart
              I agree, the L4 is a common S & B casting / forging mark, and 16DP is one of their gear tooth sizes for the model M type.
              #443799
                Not suitable for your lathe?
                If you could cut centres, might it be a better to modify these than buy originals?
                #712556
                sp@rks
                  @sprks
                  On Robert Bailey 1 Said:
                  I purchased a Harrison L5A 11 inch which came with these change wheels that are for another lathe. I would be grateful for help identifying what they fit so I can sell them and the proceeds go towards obtaining some of the right ones. There’s a total of 6, 16DP at 100 % confidence, Teeth 55, 60, 65, 70, 75 and 100. 3/4 inch bore, 1/2 inch wide, 1/8 inch keyway. The cast ones have a L4 marking and what looks like 88 or 86 but could just be marks from the runner or raiser.img_20191224_122852_7.jpg
                  Longshot I know but do you still have these?
                  #712575
                  old mart
                    @oldmart
                    I agree that the Smart & Brown model M use 16dp gears and according to my charts are the only S & B lathes to do so. And L4 is commonly used by them in part/casting numbers. Other makes may also use the same gear sizes.
                    #712616
                    Nigel Graham 2
                      @nigelgraham2
                      Not Done It Yet –
                      As a Harrison L5 owner…
                      Easier to obtain the correct wheels from, e.g. Home & Workshop Machinery, and it may be possible to trade those S&B ones in.
                      The problem with mixing change-wheels is that even if they apparently match those that came with the lathe, their pressure-angles may differ.
