Lubricator Sight Glass
Home › Forums › Locomotives › Lubricator Sight Glass
  • #1372
    John Andrews 2
      @johnandrews2
      #179583
      John Andrews 2
        @johnandrews2
        I am planning to use a hydrostatic lubricator on my 5" gauge 2-8-0.
        Can anyone tell me where to get a small quantity of glass tube about 1/2" to 3/8" in diameter. I cannot find it any of the suppliers lists.
        #179584
          6" length of water gauge glass? about £3-4
          #179621
          julian atkins
            @julianatkins58923
            hi john,
            i use pyrex test tube. are you following a particular design?
            cheers,
            julian
            #179624
            Halton Tank
              @haltontank
              Reeves do some at 12mm dia x 20mm and also at 18mm dia.
              see **LINK**
              Regards Luigi
              #179693
              Maurice Cox 1
                @mauricecox1
                Having obtained the tube, how do you cut it into short lengths? I wish to make some model drip feed lubricators from1/4" diameter glass tube.
                Regards Maurice.
                #179697
                EdH
                  @edh
                  GS Model supplies list it in their online catalogue under Misc Parts > Lubricator Sight Feed Glasses
                  http://www.gssmodelengineers.com
                  No connection, just a satisfied customer
                  #179705
                    Maurice at 1/4" you can roll it on the bench with a stanley knife blade held where you want the cut, this will score the surface all round much like a glass cutter, you can then snap the tube.
                    If you have one then a wet diamond tile saw works well on the larger diameters too.
                    J
                    #180485
                    John Andrews 2
                      @johnandrews2
                      Thank you everyone.
                      As usual I have found this a very useful and friendly forum
                      Best Wishes
                      John A
                      #180493
                      WorkshopPete
                        @workshoppete
                        Good Morning All
                        I am told by one of our members who is a keen fan of the Great Way Round that Perspex tube with a 2mm wall works well and is readily available on Ebay. Never tried it myself but intend to fit hydrostatic lubricators to my Pansy.
                        Peter
