Boxford VM30
Boxford VM30
Home Forums Manual machine tools Boxford VM30
  • #400829
    Chris Short 1
      @chrisshort1
      My Boxford seems to be getting a little warm around the area of the spindle bearing
      Ive stripped the shaft out, cleaned and inspected the bearing and it’s in pristine condition
      I’ve re-greased it and refitted it yet it’s still getting warm
      Anyone got any ideas?
      thanks
      #13455
      Chris Short 1
        @chrisshort1
        Warm Spindle Casing
        #400831
        Speedy Builder5
          @speedybuilder5
          Lets assume you have the bearings loaded up about right, then there may be too much grease in the spindle bearings! How much did you put into the bearings as they don't need much plus if you topped up by using the greasers it could overload the bearings and that would cause them to heat up – happened to me on my Boxford AUD.
          BobH
          #400839
          Brian Wood
            @brianwood45127
            Chris,
            The explanation for the heating comes from the sheer effort involved in useless churning of surplus grease and that action causes heat to be generated. In doing so it also degrades the grease in the process, tries to extrude the excess if it can and in extreme cases it can even lead to the balls or rollers skidding on the surfaces rather than rolling on them as intended; that rapidly leads to bearing failure.
            It is a situation to be avoided
            Brian
            #400847
            KWIL
              @kwil
              Speedy, there are not any greasers on a VM30 Mill
              #400862
                Posted by Brian Wood on 17/03/2019 16:08:27:
                Chris,
                Brian
                An example of differing lubrication needs for the same bearing could be comparison of the Raglan Little John and Loughborough training lathes.
                The training lathe, which only turns at up to 600rpm (a special could be ordered for 1200RPM) was grease lubed – while the LJ, which had a possible top speed of 2500rpm (most were 1750rpm), was oil lubed. Really high speed spindles use special lubricants to avoid 'shear' heating.
                The usual mantra, for greasing open bearings (in plummer blocks), was to grease with the machine running – presumably so that any excess was thrown out. Most electric motors (1425rpm) are grease lubed.
                Too much preload can cause the rolling elements to skid, too.
                According to lathesdotco, the bearings were 'sealed-for-life' preloaded Timken roller bearings'. Have they been changed for lesser quality bearings?
                #400867
                David Hughes 3
                  @davidhughes3
                  Hi Chris
                  What grease did you use.
                  #562529
                  Dan Mansfield
                    @danmansfield84090
                    Hi Chris,
                    Did you manage to resolve the issue with warm bearings? I also have the vm30 milling machine and have noticed that the lower bearing is getting hot even when the machine is running with no load being applied.
                    Dan
                    #562545
                    Rex Hanman
                      @rexhanman57403
                      My VM30 gets very warm if used for long periods. Had it (and it's sibling) since new in 1984. Now and then, when it has been running for a couple of hours or more, I get the odd drop of semi liquid grease drip from the spindle onto the table. I just squirt a bit more grease in once in a while.
                      I rarely run it at the high speed (3000rpm, later machines were derated to 2000 I believe) as the noise from the straight cut gears is deafening!
                      Lovely little machines though. Just wish it had a quill.
                      Edited By Rex Hanman on 12/09/2021 21:15:24
