The Frrankenlathe
The Frrankenlathe
Home Forums Manual machine tools The Frrankenlathe
  • #399359
    Adrian Johnstone
      @adrianjohnstone89946
      Here's a home-built lathe to give you mightmares…
      Adrian
      #13447
      Adrian Johnstone
        #399360
          Inspired re-use of the castings star
          … but pretty & petite it aint !
          OldMetaller
            @oldmetaller
            Beast! surprise
            Interesting website. I read the article on what to do if you get superglue in your eye. I'm normally very careful about eye protection, but realised that I had never considered using safety glasses whilst using superglue. I will do from now on.
            John.
            #399362
            Brian Oldford
              @brianoldford70365
              I wouldn't want to carry that upstairs.
              #399368
              jimmy b
                @jimmyb
                surprise
                Jim
                #399373
                Mick B1
                  @mickb1
                  Interesting that he has the tailstock running on separate bedways to the saddle. I've seen that before on a big Binns & Berry. It can be useful, but I'd imagine it fails value engineering to most 'proper' lathe builders. Of course it gives this guy an extra straightness/parallelism feature to look after in his build.
                  #399383
                  Clive Foster
                    @clivefoster55965
                    Shades of the multimachine https://en.wikipedia.org/wiki/Multimachine.
                    Problem with all such projects is that getting reliable repeatable accuracy over a usefully wide range is hard. Very hard. A work to 10 thou machine is probably not unreasonable. Work to 1 thou maybe if you are good and iterate through several builds. Work to tenths. Fergeddit. Thats factory built by pros territory.
                    #399396
                    Jeff Dayman
                      @jeffdayman43397
                      Man that one in Adrian's posted link is rough! Did anyone notice the Chrysler Slant 6 blocks are chained together? The article mentioned they were not welded! I'm all for home builds and found materials but this is rough even by my standards! I'm sure you can remove material with it, but accuracy and precision are unlikely.
                      Edited By Jeff Dayman on 09/03/2019 13:16:21
