Which Milling machine motor?
Home Forums Manual machine tools Which Milling machine motor?
  • #397346
    Arthur C
      @arthurc15934
      Hi, I am new to this forum and not really into model engineering as such but find a great deal of useful information here. I have an old myford ML7 and a Harrison mill (vertical) which I have had for some years, and am into old motorcycles.
      Recently the motor on the mill stopped with a burst of smoke. I have not touched the electrics since I bought it, and was originally changed to single phase by a previous owner many years ago. I have taken the motor out out and it is an old Ferguson and Sons induction motor, rated single phase and 0.75hp. The wiring on the motor was actually very suspect with crumbling insulation, not helped with it being suspended over the coolant reservoir ( not used) I guess,so will have to replace everything and rewire at the same time.
      The motor should be 2hp – so do I replace with a single phase motor or 3 phase through a VFD which could give variable speed control. The table drive is 3 phase and converted through a nest of capacitors so the latter might be better?
      I would welcome any thoughts as VFD's seem quite cheap now, but a single phase motor would be a straight swap and a VFD for the table drive?
      Arthur C
        @arthurc15934
        #397361
        Phil Whitley
          @philwhitley94135
          Going three phase is the way, if you have the cash! you would need two VFD's one for the main motor, and a smaller one for the feed motor, I would certainly go back to 2hp, 3/4 hp motor has done well to last this long! I have a harrison horizontal mill with the optional vertical head, superb machines, Single phase swap would be ok, but go for at least a 2hp motor. 3ph would be smoother, and also you get infinitely variable speeds and soft start. You could of course just get a three phase main and vfd and leave the feed motor as is!
          Good luck with it all
          Phil.
          Edited By Phil Whitley on 21/02/2019 18:49:29
          #397363
            Personally, I would not countenance fitting a single phase motor, if there is an opportunity/necessity to fit a new drive. That applies to most of my machines currently running with induction motors. Perhaps not worded ideally, but you should get my drift.
            #397375
            Arthur C
              @arthurc15934
              Thanks for the advice – 3 phase main is definitely not an option! I like the idea of a 3 phase motor. Price wise 3 phase and 2 phase look comparable to be honest. I might leave the table drive for another time. It actually blew in the middle of a job and so needs to be done. I really like the machine to be honest it does all that I need it to / am capable of so feel a little investment will be worth it.
              #397378
              Mike Poole
                @mikepoole82104
                As I was in the fortunate position of having a 2hp inverter laying around I decided to convert my VMC mill, I got a TEC motor from bearing boys and it was good service and very well packed. Although the motor is made in China it is very well made and runs sweetly. The late John Stevenson endorsed these motors on this forum and they are a fair bit cheaper than Brook Crompton.
                #397465
                Arthur C
                  @arthurc15934
                  Just had a look at the website and there is a sale on! Thanks for the tip.
                  #397471
                  Vic
                    @vic
                    My lathe and mill came with single phase motors and they both work fine. If one of them let the smoke out I’d replace it with another motor of the same type.
                    #397519
                    Arthur C
                      @arthurc15934
                      Just been looking at the rear driver pulley which is much smaller than the driven pulley at the top of the belt. This will reduce the RPM of the spindle.
                      The driver pulley on the motor was 80mm diameter which seems small. 1 turn of the top pulley in the highest ratio gives 1.75 turns of the vertical spindle. Has anyone got measurements for the driver pulley on their machine as I think it should be slightly larger than the top one to get the right spindle speed with a 1400 rpm motor or am I completely off track?
                      #397533
                      Phil Whitley
                        @philwhitley94135
                        Some one will have, but if no one does, I am back at my workshop on monday and will measure mine for you, Mine is three phase.
                        Phil
