Copper smokebox ?
Copper smokebox ?
Home Forums Locomotives Copper smokebox ?
  • #159583
    steaming lanky
      @steaminglanky
      I am ready to make my first Tich smokebox, the brass materials available will be slightly loose to the boiler O/D therefore NG. I have a short piece of copper tube which is suitable.
      Is there any reason I should not use it?
      Thanks Ron
      #1306
      steaming lanky
        @steaminglanky
        Can I use copper tube instead of brass?
        #159677
        Bob Youldon
          @bobyouldon45599
          Hello Ron,
          Provided the tube isn't soft then by all means use it, although be careful and support it well when drilling it etc. On a couple of my locomotives I have used copper tube without any problems and at present I'm refurbishing a big ugly 5" gauge atlantic that has a copper smokebox and thats probably seventy or more years old.
          Bob Youldon
          #159683
          Phil H 1
            @philh1
            Ron,
            You could also wrap a strip of brass round the boiler to form a spacer ring between the outside diameter of the boiler and the inside bore of your brass tube. I plant to do a similar spacer ring for my Northumbrian.
            Phil H
            #159694
              Ron, can I ask you to change your user name so it does not show your e-mail, one it will save it hiding text and two will stop you getting spam and as we all know spam tins don't make a good smokebox.
              Depending on how big teh brass tube is you could also run a slitting sawe along it and silver solder back together, put the joint at the bottom and it won't show.
              J
              #159716
              steaming lanky
                @steaminglanky
                Hi Guys,
                Thanks for the usefull info, I will consider all alternative and work on the best one for me.
                Regards Ron
