Myford cross slide dovetail size`s ????
Home › Forums › Manual machine tools › Myford cross slide dovetail size`s ????
  • #172240
    GT390
      @gt390
      Can anyone tell me the width of the dovetail on the ML7 cross slide ?
      I have a Hobson ML7 copy and the cross slide looks identical
      the hobson cross slide is damaged
      It is not the same size as my power cross feed super 7
      Are the dovetail`s on the early super 7 and ml7 the same ?
      thank-you
      Rob
      #12386
      GT390
        @gt390
        #172244
        Robbo
          @robbo
          Rob,
          Can't tell you the width of the cross-slide just now, can have a look tomorrow. The Super 7 s and the ML7s are different, the Super 7 is wider to accommodate the much wider gib strip.
          #172246
          GT390
            @gt390
            Thanks Robbo, the Hobson major width is just under 2-1/4", I would really appreciate it if you could measure yours
            thanks
            Rob
            #172276
            Robbo
              @robbo
              A quick measure with a vernier caliper shows
              Inside width to V points is 2.3" or 58.25mm
              Outside width is 1.95" or 50mm – outside refers to that which rests on the saddle.
              The depth of the vee (vertical, not the slope) is 0.375" or 9.75mm
              The gib strip is 3mm thick
              Sod's Law says that they will be almost the same, but not quite!
              I you want to try an old ML7 cross-slide, send me a message, but they are heavy so postage will be a lot. I have a couple "under the bench".
              #172288
              Russ B
                @russb
                Worth a mention, The Super 7 cross slide (or certainly my 1953 vintage machine) has just one dovetail and one plain machined side. The Gib strip (split in 2 halves) forms the other half of the dovetail.
                If your "making it fit" then the Super 7 cross slide with custom gib strips could offer much greater flexibility.
                This is the same as mine, you can see how one side of the cross slide is machined flat, and the gib is a rather large affair and forms the other half of the angle, (secured through the top of the slide, after being adjusted via the side screws in the normal way)
                http://homepage.ntlworld.com/bryan.rozier/mf_cross_gibs_small.jpg
                Edited By Russ B on 12/12/2014 10:31:09
                #172320
                Mike Poole
                  @mikepoole82104
                  My ML7R has the pre PCF super 7 saddle fitted with the ML7 cross slide, as far as I know the super 7 cross slide fits straight on so the saddle dovetail must be the same although the design and width of the cross slides is different.
                  #172367
                  GT390
                    @gt390
                    Thank you so much for the reply`s guys !
                    I think from the measurements Robbo provided that it is the the same size as as ML7,
                    I have uploaded some photographs to photobucket so you can see the item in question
                    Robbo, I may take you up on the offer of the ml7 slide to try
                    I only bought this machine to get the myford gearbox off it for my super7, but now I have had a play around with it, I have decided to keep the gearbox on it and use the machine.
                    The geared head is a fantastic job ! It would be a great project to copy and adapt it to suit the Myford !
                    And the spindle bore will pass 3/4" and has a #3 taper, I like the tailstock too, it has a huge amount of travel in the ram.
                    If I can confirm that the ML7 or super cross slide will fit, I would buy a long type
                    Is the ML7 cross slide feed screw 3/8" ?
                    LINK BELOW to pictures
                    http://s65.photobucket.com/user/rab_mcc/library/hobson%20lathe
                    Edited By GT390 on 12/12/2014 21:44:28
                    Edited By GT390 on 12/12/2014 21:45:00
                    #172382
                    GT390
                      @gt390
                      Looking again at my power feed super 7, I see that the dovetail dimensions are actually smaller, also as the gib is so chunky, it places the righthand slide surface a good 1/2″ to the right of the dovetail, so a super 7 cross slide will not fit the hobson, as this area is rough cast and lower, looks like a ML7 slide is the way to go,
                      #172397
                      Robbo
                        @robbo
                        Rob,
                        The Imperial feedscrew is 3/8" x 10tpi. Acme thread. Don't know metric, but similar dia presumably.
