Steam locomotive
Steam locomotive
Home Forums Beginners questions Steam locomotive
  • #551445
    Tony musson
      @tonymusson60521
      Hi all am new to locos but I have brought a 3.5 heilan lassie air tuning chassis with boiler and smokebox now it's in shop noticed what might be problem driving wheels seem sloppy axles don't fit in wheels tight is this normal am thinking are they machined this way as heat when running?any help will be appreciated this is a old new build by engineer
      P
      #10880
      Tony musson
        @tonymusson60521
        Axle
        #551450
        Former Member
          @formermember12892
          #551457
          Jon Lawes
            @jonlawes51698
            I hate to sound like a broken record but if you have a model engineering society near you someone might be able to cast their eye over it and give some guidance; it's very hard to diagnose on a forum.
            Very broadly (and I say this as someone who is not much more than a novice),
            Wheels should be tight on the axles and quartered accurately (i.e. left hand side offset to the right hand side by the same amount on each coupled wheelset, for example all exactly 90 degrees, or all exactly 89 degrees, but importantly all the same).
            Axles can have a little side to side movement in the axle boxes.
            Axleboxes can have a little slop in the horns to allow them to articulate up and down without binding.
