Z axis direction
Z axis direction
Home › Forums › Manual machine tools › Z axis direction
  • #12254
    Mike Poole
      @mikepoole82104
      #142789
      Mike Poole
        @mikepoole82104
        I have a vmc mill to which I am fitting a DRO. At the moment I am only fitting a scale on the knee and not the quill which I usually keep locked. I think the usual convention for the Z positive movement is when the cutter moves away from the work so I would interpret this to be when I lower the table, I think I should set the DRO to register a positive movement when lowering the table. Does the forum agree?
        #142791
        mgnbuk
          @mgnbuk
          That is how it would be done on a CNC machine.
          Nigel B.
          #142812
          M0BND
            @m0bnd
            I agree too. Z minus will remove material, therefore as you have said, knee up = minus.
            Andy.
            #142815
            Mike Poole
              @mikepoole82104
              It seems we all think the same way so Z plus will be knee down. Thanks chaps for your input.
              #142833
              Oompa Lumpa
                @oompalumpa34302
                So on the X axis, what would left and right be? and for the sake of completeness the Y axis?
                I have my Y axis – going away and + coming towards me. X axis left is + and right is -ve
                I just made it up as I went along but I have turned one of my DRO's upside down so it sits lower. So maybe I did it wrong now?
                Edited By Oompa Lumpa on 04/02/2014 22:17:41
                #142836
                blowlamp
                  @blowlamp
                  X + direction is with the tool moving to the right (table moves to left).
                  Y+ direction is with the tool moving towards the back of the table.
                  Martin.
                  #142843
                  Nobby
                    @nobby
                    Hi
                    When i used to set the cnc machines I Know its old hat now But i used a 5mm setting peice not my best slips . using electronic hand Wheel wind the quill down carefully take a light touch . go to controller Datum set z + 5 . As martin says
                    Always s think in terms which direction the cutter is moving z- x+ y- etc . drifting away a bit wire eroders you can program the bottom different to the top say for backing of dies
                      I would have thought the knee up on a milling machine would enable the slot drill / cutter  to take another
                    peck/cut  therefor Z minus .  I have my flack jacket on ready for replies
                    Nobby
                    Edited By Nobby on 04/02/2014 23:09:42
                    #142856
                    Oompa Lumpa
                      @oompalumpa34302
                      Posted by blowlamp on 04/02/2014 22:24:17:
                      Martin.
                      Well I got one of them right anyway!
                      Thanks for that. I will put that "right" in the morning and more likely get the next job ready for the scrap bin
                      graham.
