XJ9250 Milling machine
Home › Forums › Beginners questions › XJ9250 Milling machine
Viewing 2 posts - 1 through 2 (of 2 total)
  • #5459
    Norman Willcox
      @normanwillcox10519
      #66057
      Norman Willcox
        @normanwillcox10519
        XJ9250 from SPG Hinckley Ltd
        Has anyone any information on this machine please?
        My machine stripped the brass motor pinion, which drives a steel gearwheel, in the first few months and it stripped the lead-screw nut on the Y motion soon after. I made a new bush for the lead-screw nut on the lathe.
        Backlash on all motions was not impressive from new.
        I have always suspected the RPM and today measured it with a tacho-generator. It is 600/1750 instead of the advertised 1000/3000. That is not enough for milling Free Cutting Steel with a 3mm endmill.
        Does anyone know of a supplier of replacement steel pinions?
        Is it possible to adjust the electronic controller to increase the speed?
