WSP books
WSP books
Home › Forums › The Tea Room › WSP books
  • #34818
    mick70
      @mick70
      #272188
      mick70
        @mick70
        right my eldest boy just rung asking what ESP books i want.
        i can choose 5 any recomendations?
        i have
        3 screwcutting
        6 measuring and marking
        8 sheet metal work
        12 drill taps and dies
        13 workshop drawing
        14 making small workshop tools
        15 workholding.
        17 gears and gearcutting
        22 workshop electrics
        24 electric motors in workshop.
        26 home workshop hints
        28 simple workshop devices
        31 useful wshop tools
        34 lathework
        37 dividing
        38 tool and cutter sharpening
        39 model engineers projects
        42 metalworkers data
        43 mini lathe
        45 basic lathe work
        48 mini lathe tools.
        #272212
        Enough!
          @enough
          Posted by naughtyboy on 16/12/2016 13:32:42:
          – 97 Clairvoyance
          – 105 TLAs in the workshop
          smiley
          More seriously …. I would definitely get #12 Drills, Taps & Dies. ***
          It's a mine of useful information and is the only book of this type that I've read from cover to cover rather than using it mostly as a reference.
          ( ***If you read Eats, Shoots & Leaves at the same time, don't get confused.)
          Edited By Bandersnatch on 16/12/2016 15:42:21
          #272223
          ASF
            @asf
            No 3 On screwcutting
            On second reading, you have that one `Doh
            Edited By ASF on 16/12/2016 16:34:57
            #272232
            Enough!
              @enough
              Posted by ASF on 16/12/2016 16:17:31:
              …er … doh from me too. I misread that bit – sorry NBblush
              #272241
              richardandtracy
                @richardandtracy
                4 Foundry work for the amateur.
                There is another foundry one, bit can't remember which.
                I don't often use my furnace, but the knowledge is a good backstop just in case.. The foundry can be very, very basic. Mine is here **LINK**, and has been fired by pallets to melt a pound of aluminium at a time.
                Richard.
                #272246
                Roderick Jenkins
                  @roderickjenkins93242
                  Milling in the lathe. Never mind the lathe bit it's an excellent treatise on milling and milling cutters.
                  HTH,
                  Rod
                  #272269
                    Posted by Roderick Jenkins on 16/12/2016 17:53:18:
                    +1
                    'Spindles' is supposed to be very good, but i haven't read it.
                    I.M. OUTAHERE
                      @i-m-outahere
                      3 ,17, 37,38 and 42 are the ones i found most useful but the entire series is a "must have " as far as I'm concerned .
                      The data book is pretty useful and i found it was the one i reached for first as it is easy to use and not full of information that you will more than likely never use , i feel machinerys hand book is a bit like that !
                      Sooner or later you will need to :
                      Sharpen your cutting tools
                      Use gears
                      Cut threads
                      Or use a dividing device of some sort to either cut gears or make a dial etc .
                      I have read the lot ,I can't say there is one bad book amongst them and if some bright spark could put them into one big book it would be fantastic !
                      #272293
                      ASF
                        @asf
                        Posted by Neil Wyatt on 16/12/2016 20:19:28:
                        +1
                        I purchased Spindles on a whim from Amazon, as it was really cheap (a few pen notes inside), and I confirm it is a good read
                        #272358
                        Hopper
                          @hopper
                          26 Home Workshop Tips and HInts makes good Christmas reading. All sorts of old time dodges and ideas for all manner of stuff there.
                          #272388
                          Old Elan
                            @oldelan
                            I wouldn't bother with No 22 unless it has been revised.
                            My 1994 published copy is hopelessly out of date.
                            Edited By Old Elan on 17/12/2016 15:28:50
