WIN 10 again!
WIN 10 again!
Home Forums The Tea Room WIN 10 again!
Viewing 25 posts - 26 through 50 (of 53 total)
  • #349259
      I enjoyed being labelled as an 'attitudinal rebel' by7 Muzzer. That's me – a cross between James Dean and the Fonz, so cool it hurts…
      Back to Clive's problem: sounds unpleasantly that it's not even getting though the BIOS boot stage. (This BIOS is a simple built-in rarely changed program in firmware with a basic understanding of what the computer's hardware is: CPU type, real time clock, memory and peripherals.)
      When you switch on a computer it jumps to the beginning of BIOS memory and executes whatever it finds, all being well setting up basic interfaces to the screen, hard-disk and other peripherals. Once it's set the scene, it reads another program off a fixed part of the hard-disk that understands how to launch the operating system. It's called the booting as a reference to 'pulling yourself up by your boot-straps', which is impossible. Actually all it's doing is starting with a tiny program that calls a series of bigger programs until it knows enough to launch the operating system. You have probably spotted that W10 is some distance down the chain.
      Usually the boot process is pretty solid but it can be disrupted by a hardware failure or by corruption of your hard-drives boot sector.
      Diagnosing and fixing this can be difficult. The approach generally is to:
      1. Try and get to the BIOS menu. This is done by repeatedly tapping a function key while the machine powers up. Which key it is varies, usually F2. Unless your system has a boot screen that tells you when and what to type, start tapping the instant power is switched on. There is only a brief window when you access the BIOS.
      2. Once in the BIOS it will let do some simple checks and alter which device the system boots off. Sometimes there's a list that will be tried automatically in sequence – typically Hard-drive, the USB, then DVD. Other times you have to tell it which device to use. The idea is get the machine to boot from something else (like Linux) on a USB memory atick or DVD. If you can get that far, the BIOS is OK, and the fault is likely hard-drive failure or corruption. If you know what you're doing, it's possible to explore the hard-drive with linux. It may be possible to save data, or even fix the corruption. This is similar to the Microsoft recovery process, which is packaged differently and may be easier to follow.
      Attempting this can soon get you into time-consuming advanced computing. Professionally, we didn't mess about. When a user machine failed it was swapped out. Back at base no attempt was made to fix old machines, failures within warranty generated claim paperwork, and only newish boxes were serviced. If it wasn't an obvious fault quickly fixed by board or disk swapping, it was sold to a refurbisher. Occasionally corrupt disks were fixed by copying a new image to them. That destroys user data on the disk. In our configuration there wasn't any – it was all held on a fully backed up central server. Not so easy on a home system.
      None of this helps I'm afraid. If it's as dead as I fear, you'll probably have to take it to a PC Repairer. It feels more 'seized engine' than 'needs a bump start'! Repairers have the skills, software and hardware needed to diagnose difficult cases. Perhaps someone else on the forum can help.
      Sorry,
      Vic
        @vic
        Peter, the best deal I’ve had was on a “nearly new car” it was a pre-registered Honda with delivery mileage (7miles on the clock) and was about £3K cheaper than the “new” model. I prefer nearly new cars as the saving can be significant but my current car was bought new because they didn’t have any nearly new ones at my local dealer. They did give me a very good trade in on my old one though and there were other discounts on it as well. It is nice having a brand new one though!
        #349276
        Clive Hartland
          @clivehartland94829
          OK, I am in, I did it by switching on and off as the circle of dots processed. As it started to open press the off switch until it closes and then do it 3 times. This then comes into a repair mode which chugs through boot up after boot up until eventually I ha a working laptop. It told me that some upgrades did not load but i am not going to try to load them.
          I feel that Microsoft have failed again as I read something about older processors not liking Win10.
          #349299
          GoCreate
            @gocreate
            Had the same problem 3 times on my Acer desktop after a win10 update. First 2 times got into repair mode, 3rd time I could do nothing and had to reinstall win10 from an ISO image then reinstall all my sofwares and files.
            Mght he coinsidence but after changing the internet settings to "metered connection" there are significantly less updates and have had no more problems. I had come to hate win10 but since the last reinstall and making this setting change a year ago I'v been ok with it
            My better half has hard similar experiences on a Toshiba laptop.
            I find Britec on YouTube to be a good source of help for dealing with win10.
            Nige
            Edited By tractionengine42 on 08/04/2018 05:28:14
            Edited By tractionengine42 on 08/04/2018 05:29:14
            #349333
            Ady1
              @ady1
              There was that chip security issue as well recently, some updates may have tried to deal with it
              #349339
              Peter G. Shaw
                @peterg-shaw75338
                Hi Vic,
                Lucky you.
                The nearest main dealer to me was a Honda dealership, and I went to see them. They tried to sell me a CRV, which I didn't want – too high, I couldn't see over it. After that they lost interest and I had to pester them to get a look at a true estate – unfortunately it didn't suit.
                Eventually I bought Toyota, and never regretted it.
                Peter
                #349358
                FMES
                  @fmes
                  Conversely, try loading windoze xp onto a modern laptop, it just won't happen.
                  I have a Minolta slide scanner that due to it age, will only run on the latest of WXP as I discovered when attempting to run it on a W7 machine – just wouldn't work.
                  Bought a new laptop with no OS and as I had plenty of XP versions now not being used, went to load up.
                  After loading in all the various files, the laptop promptly reported that the OS being loaded was not compatible with the current BIOS.
                  So now you can't even backdate when you want to.
                  Incidentally, I hardly feel that not being able to see over a car is a valid reason for not buying it. devil
                  Lofty
                  #349392
                  Ian S C
                    @iansc
                    I FOOLED IT, I wrote earlier that W-10 wouldn't recognize my camera, today I plugged in my film slide copier, then the camera, and went in via that, it worked for me so I'm sort of happy.
                    Ian S C
                    #349394
                      Posted by Ady1 on 08/04/2018 10:31:25:
                      That's possible. Although the press have lost interest the MELTDOWN / SPECTRE thing is still rumbling on. It seems there are:
                      • some older processors that cannot be secured
                      • patches that are themselves faulty in that they crash a minority of processors or cause other problems.
                      • more fixes to come now the extent of the problem is better understood.
                      On my home machines all the upgrades so far (Window10 & Linux) have applied successfully. Performance-wise nothing has obviously slowed down here – yet. It looks like the performance hit is unlikely to effect ordinary users. More serious for the grown-ups – some server owners have reported a 30% performance hit. How bad it is depends on the machines work-profile. A CAD rendering back-end is more likely to be hurt than a lightly loaded web-server.
                      Delighted to hear Clive has got his computer running again; that does point the finger rather firmly at the Microsoft update. I suggest running Microsoft's chkdsk next as described here. Not difficult. With luck it will detect a shower of disk errors and correct them!
                        Posted by FMES on 08/04/2018 12:11:24:
                        Lofty
                        I suspect you know about UEFI already? If not, it's a security measure controversially pushed by Microsoft whereby the BIOS will only load a recognised operating system. Initially only Microsoft was ever to be 'recognised'. That attempt to crush the competition was challenged successfully, and you now have the choice.
                        Personally I think UEFI is a mess. From Microsoft's point of view it worked a treat. UEFI makes it harder for people to switch to Linux or to perpetuate XP on a new machine. It's a decent earner because many find it easier to take W10 rather than to swim against the tide.
                        UEFI may need to be switched off in the BIOS before XP can be started. Beware, if you turn UEFI off, then Windows 10 won't start in Legacy boot mode.
                        The other option is to install Linux plus a Virtual Machine like VirtualBox. You don't have to learn or use linux itself, just use it to host XP in a VM. As such it can be a minimal installation. Equally possible to host XP from W10 in the same way.
                        VirtualBox (other products available) makes it surprising easy to do. At the cost of some drop in performance you can bypass all the boot/BIOS obstacles. Linux and VirtualBox for Linux are both free.
                        Russell Eberhardt
                          @russelleberhardt48058
                          Posted by Oldiron on 07/04/2018 12:37:36:Most people expect their PC/Laptop to boot up as soon as they switch it on but if an update has been scheduled this will not happen. The PC needs to be given time to install & configure the updates. I have a sister in law that phones me every month or 2 and tells me her pc will not start. I ask when was the last time she used it and the answer is always " a couple of weeks ago" I have lost track of the times I have told to her to turn it on and walk away from it for half an hour. It always works when she does that.
                          If I go on holiday for two weeks I expect my car to start when I find it in the car park. Why should you expect a computer to be any different. My desktop computer boots and is ready to use in 45 seconds using Linux Mint and just a little longer using Win 7. Why can't Win 10 do the same?
                          Russell
                          #349511
                          modeng2000
                            @modeng2000
                            My laptop with W10 Home boots up in under a minute. Perhaps it isdue to the solid state drives.
                            #349536
                              Posted by modeng2000 on 09/04/2018 10:28:22:
                              Certainly. But I'd also suggest the way Linux handles updates is superior. Windows can be quite annoying:
                              • without asking it sometimes applies updates during boot, which can greatly extend how long it takes to do user things
                              • sometimes applies updates during shutdown, less annoying unless you need to turn the machine off because you're going out
                              • often requires at least one reboot to complete or progress the update process. (My record number of reboots for a single installation required is 7. )
                              In comparison, Linux always asks permission before applying updates. It also maintains a much clearer separation between user-space and the system, which means that updates rarely require linux to be rebooted. Typically, application updates don't require a reboot. Only security changes deep inside the kernel, or a new kernel, require linux to be restarted, but again, you have the choice between restarting immediately or waiting until the next natural break. In contrast, Windows is much more likely to need a reboot when an application is updated, and it is much more likely to walk over the user when doing so.
                              That Windows has a flawed update system is more obvious to Linux owners who use Windows occasionally. If you use Windows regularly, updates are less obviously intrusive because they're spread over several days. They're even less obvious if you leave your computer switched on overnight and it updates while you're asleep.
                              Linux users (like me) tend to use Windows irregularly, which causes big queues of updates to build up. Next time I fire up Windows, I'm likely to get at least 10 minutes of compulsory time-wasting, likely a lot longer. Not just Windows updating, but the virus checker and other utilities will do the same, often bombarding me with adverts in the process. Not entirely Windows fault. The thing I most dislike about Windows updates is that in their desire to push services some upgrades override my security/privacy settings. I always have to check Windows updates haven't switched things I don't want back on, another time-waster compared with Linux.
                              I'm not trying to sell Linux; if you rely on a Windows only application like Fusion360, or you're an old-dog with better things to do than learn new tricks, or you're happy with Windows, stick with it.
                              Edited By SillyOldDuffer on 09/04/2018 12:05:42
                              #349537
                              FMES
                                @fmes
                                Oooh, is it broken?
                                Me gaming tower does 14 seconds from button press to desk top. devil
                                Bit of a s*d to carry around though.
                                Lofty
                                #349545
                                Russell Eberhardt
                                  Posted by FMES on 09/04/2018 12:05:30:Me gaming tower does 14 seconds from button press to desk top. devil
                                  O.K. if it's a competition, my laptop is up and ready in just under 3 seconds. Running Linux Mint 18.3 without a SSD drive. It goes into suspend when I close the lid and wakes up when I open it. It hasn't been rebooted for 12 days, not since I last ran Windoze on it laugh
                                  Russell
                                  Edited By Russell Eberhardt on 09/04/2018 13:13:50
                                  #349549
                                  Ian S C
                                    @iansc
                                    My lap top is a bit slow starting up, 7 seconds on average.
                                    Ian S C
                                    #349564
                                    FMES
                                      @fmes
                                      Posted by Ian S C on 09/04/2018 13:40:02:
                                      Ian S C
                                      Thats a bit more like it.
                                      Shows how much crud windoze loads in.
                                      #349567
                                      Speedy Builder5
                                        @speedybuilder5
                                        What does 'Boot Up' mean, is this how long you kick a Windows machine in desperation. I don't close my MAC Book Air down, just shut the lid. On re-opening, enter password and go. It takes longer to type the password for the window to open – Ah! the joy of ditching Windows.
                                        (Name withheld)
                                        #349698
                                        Vic
                                          @vic
                                          Posted by Ian S C on 07/04/2018 15:05:28:
                                          The only problem I have since I went over to W 10 from W 7 is that the computer will not recognize my 12 year old Sony DSC-W5 camera.
                                          Ian S C
                                          I’m not surprised, it came out in 2004! Have you thought of getting a new one, 5mp isn’t very much these days, even mobile phones are higher than that.
                                          #349720
                                            Posted by Speedy Builder5 on 09/04/2018 15:26:46:
                                            (Name withheld)
                                            I do the same on my Windows laptop. I've seen my daughter on the edge of rage trying to do things on her mac that take seconds on a PC.
                                            That said, convergent evolution of computers is so strong now that most of the advantages one group of users claims over another are illusory and most things are easy to do on any computer if you know what to do!
                                            Muzzer
                                              @muzzer
                                              Indeed. By ditching Windows, you no longer know what Windows does these days but clearly OS endows users with the illusion of psychic powers(??). Like Neil I just close the lid. When I open it again it's there as before. Even booting up these days is damned quick.
                                              Murray
                                              Edited By Muzzer on 10/04/2018 19:19:38
                                              #349889
                                              Raymond Sanderson 2
                                                @raymondsanderson2
                                                This sounds like the trouble I had when I lost all digital stored ME & MEW but that was months ago and the removal of WiFi card fixed it as well as installing new STD.
                                                #349924
                                                Robin
                                                  @robin
                                                  Posted by Raymond Sanderson 2 on 12/04/2018 07:13:04:
                                                  I am not always up to date with the lingo, but did you mean SSD? face 22
                                                  #349938
                                                  Gordon W
                                                    @gordonw
                                                    I switch the computer on, take the dog for a walk ,and the thing works. Win 8 in a black box.
                                                    #349942
                                                    Vic
                                                      @vic
                                                      Posted by Robin on 12/04/2018 10:52:19:
                                                      Ha Ha, nice one! smiley
