I hear stories of the lathes that only a vicars wife has been using on sundays to turn candles for diner tabel, but never seen one here.
I’m not wery experienced but maybe I’m not very inexperienced either. I hope someone can learn from this. Long story and fun to have a field day with, enjoy.
MY INPUT: When it comes to choosing a lathe I believe it’s hard to buy right one first time.
If you are new to hobby, try to learn from this and prepare to do your own mistakes – it will be a character building experience!
Snif I:
Sometime time round 1993 – 1995 or so I was buying my first own metal lathe, I had been using some ten years earlier good lathes at the school – I sort of had an idea what lathes do, but I never used cheap/small lathes before.
My choices (Pre EU, Pre internet) were practically limited on what was advertised on ME mag.
I was considering Myford Diamond 10, but the smuck brochure and high price of accessories put me off. Also it was just a tad too big for my two room apartment (HAH! I moved to house only two years later and then I got an in-house-garage).
Because I never seen on tried them before and there was no way asking opinion of fellow model engineers then (ah… the internet), I was buying my first lathe on speck only – you know the claims seller dares to put on paper. Only thing relatively clear is centre height and such. This gives you an idea what you can clamp on chuck or bolt onto face plate. It really doesn’t mean you can machine it!
I bought “Minilor” with some accesories and was planning to buy some more accessories. Buying that petit merde was one of the biggest mistakes on my life. Never trust Frencies – incidently I had Citroën Xantia for years and although it had some excentric engineering it was a nice car and gave me years of joy. Not so rosy experince with the lathe though.
See this: http://www.lathes.co.uk/minilor/index.html
It gives a whole lot more glossy picture of the product than it is in reality. Plastic knobs could be replaced etc. obvious things. It looks quite handsom on the picture, but apron/cross slide, tool holder, tail stock, spindel stoc etc. are made of “Special alloy” or something like that on advertising text. It could be zink or aluminium, but it’s pretty miserable stuf for a metal cutting lathe. Also the only the transvese lead screw it trapetzoidal, all others are standard 60 decrees.
BIG MISTAKE buying on speck only, those numbers give you some indication, but after a mistake you learn to read between the lines.
I did send my letter to a dealer explaining my reasoning on how fit this is to purpose, but I got back a friendly letter, little sympathy and couragement to learn how to use it. I could not have sent it back anyway, losses would have been too great with the customs, air freight etc. I just had to swallow my anger and pride and do with a totaly inadequate lathe.
Part of disapointment was my own fault, I bought a lathe that would be small enough to fit into my appartment easily, but it would not be big enough for anything more than most immediate needs. Think big.
This lathe would have need a major redesing and converting it to a usable one would need a large milling machine and lathe to fabricate all other components but lathe bed, lead screw, chuck, motor and maybe a tail stock barrel. Maybe I’ll take it from there after I buy a good lathe and it has done it’s purpose of being unused expensive ornament on my garage.
Did I learn from this? NO. Can’t even sell it, because only someone who is just startting a hobby would buy it. Karma would get me in the end.
Actually, I learned a little, but it was expensive to learn:
* I learned what not to buy = on tec spec only.
* I knew better how lathe size and work size relates, specially on flimsy machines
* I was pretty fed up with this “quality”
* I will never buy from this supplier again – fool me once….
Snif II:
I checkked Myford once more, and on that time the price was way too high to me. Part was strong pound, part was that they had dropped cheaper machines from production. To me it would have made sense to buy an entry level machine and after assesing the quality be confident eneugh to by later a bigger machine. Call me an old fool, but from any wendor I buy first something small just to find out how it works.
I got pretty good price on about myford size lathe, 120 kg. MT4 head stock, MT3 tail stock. This time I knew that the qulity would not be there, but neither would be the risks. With this amount of the money I could not have had ANY Myford from UK to my front yard and not to mention that I would have bought it without seeing it and arranged pick up, freight etc.
So I bought pretties flower of communism: CQ9325, it was deliverd in a van, I measured it with a test bar and it seemed to be ok. No plastic gears this time. Ugly as hell, but I was buying cheap.
This guy seems to happy with it:
http://users.picknowl.com.au/~gloaming_agnet/cq9325rev.html
However, this lathe has few short comings:
* Ergometry is very poor, some features are outright dangerous
* Tailstock travell is 35 mm, speck says 50 mm, way too short even on speck.
* Tailstock design is poor in every respect.
* Toolpost/topside design is weak
* Belt drive abysmal, adjustement, dessign, motor mount is marginal. Myford style is superior.
* Handles are crooked, many holes looks like they hand drill these “on situ”.
* Weird bed wi
