Which Loctite?
Which Loctite?
Home › Forums › Beginners questions › Which Loctite?
  • #6086
    Aestus57
      @aestus5782081
      #88860
      Aestus57
        @aestus5782081
        Hi Folks,
        As part of the horizontal mill engine I'm building, I've put together a built up crankshaft. Now, I've never used Loctite before so how do I degrease the parts and which number Loctite would you recommend. question
        Thanks
        Peter
        PS the shafts are 5/16" Dia silver steel and the crank webs are 1/4" X 1/2" BDMS
        #88861
        David Littlewood
          @davidlittlewood51847
          Hi Peter,
          For this application I would use Loctite 638 High Strength Retainer:
          Loctite
          It may be a confession of sloppiness on my part, but I've never found retainers are that fussy about degreasing; a quick wipe with acetone will do it.
          David
          Edited By David Littlewood on 10/04/2012 14:23:24
          Edited By David Clark 1 on 10/04/2012 20:39:23
          #88863
          Ian S C
            @iansc
            Loctite 620 would be a good one, you can get a cleaning fluid, but I just use meths.It sets in 30 min, or 5 min if you use Primer 1, I use a similar one from another maker Lokeal, can't remember the number. Ian S C
