More to the point, what top and front rake should we use with HSS tooling on perhaps the most common materials.
Viz: Steel, S.Steel,Cast Iron,brass,copper and Aluminium.
Should the front of the tool be parallel to the axis of the lathe, or part left or right.
What speed should we use to minimise chatter (assuming that we have reduced tool overhang, tightened slideways etc). I frequently start off in back gear and then revert to normal as the diameter reduces (Oh for variable speed etc).
I guess this has all been answered before, but is there a wall chart or something we could print off ?
