At the rtisk of adding fuel to the fire .
precision vice.
vice === device for SECURELY holding work "down" for machining.
I doubt any will materuialy disagree with that.
Precision on the other hand is more slippery
If you have vice A which is repeatable and "nice" to use a job can be set rapidily with little fuss.
Vice B is a pig and needs coaxing to hold squarely and repeatiedly ..
two situations arise. for making P parts
1 cost A N* X pounds cost B X pounds
2 setting time A Y minutes setting time B M*Y minutes
payback time A = N*X/(Y*P)
payback time B = X/(M*Y*P)
thus pb A /pb B = M*N …which after all that seems obvious..
ie if vice A cost 10 times as much It must be setterable in tenth of the time…
that is of course if payback time means anything.. my hobby time is limited so I wish to reduce setting time but my budget is also limited.. and who can estimate M from a catalogue anyway!…
Seriously ….
Brand does not ensure quality any more..( its worse since quality itself appears to be inconsistent….. " reserve the right to alter specifications at anytime"…)
The OP was able to fettle his vice .. and has something fit for his needs ( and who else can say what they are) ..we have all had experience of "buyers remorse" and will unfortunatly will continue to do so.
… I plan this to my last on this ..
Jason
