What’s this
What’s this
Home › Forums › Workshop Tools and Tooling › What’s this
  • #18483
    Martin Faulkner
      @martinfaulkner67684
      #293800
      Martin Faulkner
        Hello all, just been cleaning my big box of lathe bits. I have a Boxford lathe and came across this. Can anyone tell me what it is?1492454624460874149501.jpg
        #293801
        Martin Faulkner
          #293802
          Curtis Rutter
            @curtisrutter61973
            Looks like a chuck backplate to me
            #293803
            Stuart Bridger
              @stuartbridger82290
              Catch plate for between centres turning?
              #293805
              Martin Faulkner
                There are no threads in the middle so I ruled out a chuck plate unless there is some forms of bolt on method. All this is new to me. I was just working through the box of bits that came with it. I don't even know if it is for a lathe.
                Catch plate? Is that the large round plate with the pin on the outer edge? This is only around 60mm diameter.
                #293813
                Martin Faulkner
                  If anyone can help. Think this should be in workshop and tooling Section? Tried to change it but can not find any options to do so.
                  #293817
                  Martin Cargill
                    @martincargill50290
                    Blade flange for a woodworking saw? What is the bore size?
                    Edited By Martin Cargill on 17/04/2017 21:04:06
                    #293819
                    daveb
                      @daveb17630
                      Man with a magnet stuck to his leg?face 1
                      #293822
                      Martin Faulkner
                        Not sure on the blade flange, it's got 2 holes and a nipple. Can not see how it would hold a blade. It not my leg, it's the 10,000 tons of steel stuck in the fabric of the pants. Lol20170417_211011.jpg
                        #293845
                        Martin Cargill
                          @martincargill50290
                          The reason I said blade flange is that some blades use drive pins to stop the blade from tightening and to stop them from spinning off during braking. I see a few of them that have a range of holes to work with different blade pin holes(it's easier to drill a flange than to drill a hole in a blade)
                          #293969
                          Martin Faulkner
                            Posted by Martin Cargill on 18/04/2017 08:03:39:
                            I do understand what your saying and have not ruled out your idea.
                            The center hole diameter is 11/16 or 17.6mm.
