what is this tool for?
Home › Forums › The Tea Room › what is this tool for?
Viewing 25 posts - 1 through 25 (of 29 total)
  • #349151
    Tractor man
      @tractorman
      img_1550.jpgimg_1549.jpgHi gents,
      not got a bald clue as to the identity of this tool.
      It is well made but has no markings at all, its not an accurate measuring tool but I did wonder if it was for setting something up.
      the long end unscrews to open the centre slot which is sprung. it operates a bit like a tap wrench but its clearly not of that family.
      #35162
      Tractor man
        @tractorman
        #349513
        Tractor man
          @tractorman
          Wow over 300 views and not an opinion ventured. Must be a record.
          I’m still in the dark as to it’s possible use but I’m sure it will become clear.
          #349519
            You may have found the Holy Grail – a tool that no-one can identify!
            Does the short end swivel at right angles to the long handle? It looks as if bits of the handle unscrew possibly so it can be used in a confined space. An adjuster of some kind? Could it be for adjusting the tension of wires used to brace wood frame aircraft? Or forming piano wire?
            Baffled.
            Martin King 2
              @martinking2
              Well! Its certainly got me stumped! No idea at all.
              martin
              #349528
              Gordon W
                @gordonw
                No idea at all. It does look as if something is missing- the "radius" on the two jaws looks to made to fit to something ?
                #349531
                Tomk
                  @tomk39956
                  The shape of the jaw looks like it could hold a woodruff key.
                  #349534
                  Fowlers Fury
                    @fowlersfury
                    Cropping a couple of the pics followed by a "reverse image search" on Google gives no clue either !
                    #349535
                    Martin Kyte
                      @martinkyte99762
                      Where did it come from and was it amongst other stuff. If so what.
                      regards Martin
                      #349555
                      roy entwistle
                        @royentwistle24699
                        The upper tool in the photos, I think, is a measuring stick. Although it's got the proper numbers along the bottom
                        Roy face 1
                        #349569
                        Speedy Builder5
                          @speedybuilder5
                          What is the "bruising" between the two knurled sections on the LH handle. With a Swiss file, test how hard the centre 'link' is.
                          #349573
                          Speedy Builder5
                            @speedybuilder5
                            This doesn't help, but would give us a whole load more to think about.
                            Martin Cargill
                              @martincargill50290
                              A bore gauge? Are the knurled bits removable in stages? do you measure between the two points?
                              #349587
                              John Penfold
                                @johnpenfold74932
                                A pensioner’s tool to use on a burglar?
                                #349603
                                paul rayner
                                  @paulrayner36054
                                  Posted by John Penfold on 09/04/2018 17:41:05:
                                  not sharp or long enough mate
                                  #349618
                                  Tractor man
                                    @tractorman
                                    I can think of many a better implement to deal with that scumbag! Have you seen the shrine to him? Disgusting!
                                    Still clueless on the tool so I will post more images and do some research.
                                    #349633
                                    David Colwill
                                      @davidcolwill19261
                                      It's an epilator for engineers.
                                      Just hand it to a group of them and watch as they tear their hair out trying to figure out what it is. smile p
                                      Edited By David Colwill on 10/04/2018 08:37:33
                                      #349642
                                      pgk pgk
                                        @pgkpgk17461
                                        Put a replacable hooked blade in the centre and attach to the rim of an industral sized baked bean can and oscillate..
                                        #349682
                                        Tomk
                                          @tomk39956
                                          I think you have bits missing which would solve the mystery as to what this tool is. I think its a bore gauge. This link may help
                                          Tom
                                          #349683
                                          Georgineer
                                            @georgineer
                                            It's a grostling iron.
                                            George
                                            #349687
                                            Brian H
                                              @brianh50089
                                              Posted by TomK on 10/04/2018 15:15:15:
                                              Tom
                                              What a shame the label is damaged.
                                              Maybe we could contact the people who've bid on it. Maybe someone knows what they've bid on.
                                              Edited By BDH on 10/04/2018 15:41:39
                                              #349689
                                              Peter Krogh
                                                @peterkrogh76576
                                                Except for the short length, it looks very much like a dent removal tool for shot gun barrels. The ramps are too short for it to be a sensitive measuring tool. I suspect it's for use in tubular parts….
                                                Hang all the Vincents!!
                                                Pete
                                                #349696
                                                  From the ebay pic, clearly a tube expander of some sort
                                                  #349704
                                                  Peter Krogh
                                                    @peterkrogh76576
                                                    With only two 'sides' to expand it would need to be rotated to expand a tube in stages? This one has me very curious. I hope someone can identify it!!
                                                    Pete
                                                    #349705
                                                    Tomk
                                                      @tomk39956
                                                      The item is a Lushington No.1 Clutch Mandrel / Alignment Tool
                                                      link
                                                      Tom
