What Did You Do Today 2025
Home Forums The Tea Room What Did You Do Today 2025
Viewing 2 posts - 151 through 152 (of 152 total)
  • #803595
      It looks like you got the stud hole that you used at the junction of the two in the wrong place. looking at the photo if the holes are 1/4″ then it is about 3/16″ closer to the central recess than all the other holes. If you had picked any of the others when you machined the flat you could have got away with it.
      hole position
      Nigel Graham 2
        @nigelgraham2
        Not quite Jason. That’s where I had to chop both but especially the larger cover about a bit to make them both fit. The holes all lie on two pitch-circles that are tangents at the common one. I drilled them before forming the flats, but I think what threw it was mis-reading my own drawing for the various diameters.
        Mulling it over I realised this construction can never give the effect I wanted, but can be done by making a single plate shaped like a figure ‘8’.
        Studying the one photograph I have of the original engine, it’s clear that the covers were not circular, but more ‘D’-shaped, the bolt-hole pattern reflects that, and they were quite deeply dished, but the image is at too low an angle and too far away to show the true form.
        So I have just spent something like 3 hours re-drawing them to something like the photo:
        The LP cover studs all lie on a circle except for the central one – displaced slightly to centre between the cylinders.
        The HP studs are all at 60º angles but have two displaced outwards so the outer ones lie parallel with the straight edge. The central hole is on the pitch-circle and was the leading one for generating the rest.
        There is no real reason why the arc in the LP cover recess cannot continue round to meet the straight wall, with a fillet formed by the cutter.
        I’ve also realised the underside can stay flat. These covers, unlike the crank-end ones, do not need closely register with the cylinder bores.  It could be a single plate but I thought that would be harder to make flat all over.
        Overall length just over 5 inches. Height 3/8″ , recesses 3/16″ deep. LP cover 3.25″ dia.
        Cyl covers top redrawn 3D 2
