What did you do today? (2014)
Home Forums Work In Progress and completed items What did you do today? (2014)
Viewing 25 posts - 1,476 through 1,500 (of 2,328 total)
  • #161484
      Thanks, Clive
      … I will have a look, later.
      Clive Hartland
        @clivehartland94829
        The Comet has now been quoted at 300 kgs per cu.mtr and it is suggested it would float on water. There is so much conjecture going on now and I would think it best to wait until Philae has landed and carried out sampling. Landing site decision will be made on Monday.
        #161491
        Clive Hartland
          @clivehartland94829
          #161507
            I'd like to see a diagram that shows what the gravitational field of such an odd-shape looks like.
            The amount of structure is vastly more than I was expecting.
            Oompa Lumpa
              @oompalumpa34302
              So, today I chopped up some bits of tube and made a stand for the Drill Press. Yes, it is upside down and looks weird but all will become clear tomorrow:
              #161540
              mike smith 5
                @mikesmith5
                Been to Shrewsbury steam fayre to set up the portable railway track , should be a great weekend with loads of exhibits , pop in and say hi . Fingers crossed now for the weather. Sorry no photos .
                #161575
                Oompa Lumpa
                  @oompalumpa34302
                  Started early and put the new stand in place, levelled it off and had prospective son in law (Handy big lad) give me a lift up with the drill press.
                  Now you can maybe see the theory behind the stand and those weird protrusions. I had to grind a little of the weld in the top right corner, it was a tight fit:
                  All I am waiting on now is the motor to arrive, hopefully it will be here Tuesday.
                  graham.
                  Edited By Oompa Lumpa on 23/08/2014 10:40:39
                  Edited By Oompa Lumpa on 23/08/2014 10:42:14
                  #161596
                    Very nice, Graham.
                    I fixed a broken 12V fluorescent fitting. After ages fruitlessly searching for another one to take the 'works' out of, I had a brain wave. Popped in two 12V white LED panels, now it's brighter and probably uses less current too!
                    Involute Curve
                      @involutecurve
                      Finally got finished moving house! this is the first time in over two weeks that I can use the computer, why is it BT can disconnect you in a heart beat, but take over two weeks to reconnect……
                      I still have most of the workshop equipment to move, I did manage to get the Harrison lathe the Mill drill the Clarkson grinder and the saw shifted, I'm still unsure if the Hiab will have the reach to place the Hurco close enough to wrestle it in the rest of the way, we shall see, one of the problems is a small Hiab will get under the tree but will it have enough lifting capacity, I need to lift 1750kg rollers are out most of the drive is gravel.
                      any thoughts / suggestions are welcome…..
                      Shaun
                      #161616
                      Bob Brown 1
                        @bobbrown1
                        Shaun,
                        You could move the machine with a teleport forklift, I hired one to lift a fuel tank over a garage weight was not an issue just the reach 7meters, the price including the driver was £85.00. You may find a local farmer with one who may well do the job for a few beer tokens.
                        Bob
                        #161618
                        JohnF
                          @johnf59703
                          Shaun, have you considered laying builders plywood sheets on the gravel then use rollers, you would need two sheets so you can move one forward as you go. Not sure of the weight of your machine but we used this method to move a Smart & Brown lathe weight 1 ton, worked just fine using scaffold tube as rollers. Good luck
                          Bob Brown 1
                            @bobbrown1
                            He had 1750kg in his post hence the teleporter as I doubt very much that sort of weight on rollers on plywood would work never mind all the effort just to save a shilling!
                            Great believer in right tool for the job!
                            I will have 5 glulam beams 270mm x 90mm x 5mtrs to lift into place for the new workshop and intend to use a Hiab because I have access to one, could struggle with ropes etc………. sod that.
                            #161638
                            Boiler Bri
                              @boilerbri
                              I ran my sm32 loco packed up on a baking tray with meths and water involved and the weather was hot and sunny, I really enjoyed it. Tomorrow I will be in Llandudno for the public running session on west shore on our new track.
                              Bri
                              #161640
                              DrDave
                                @drdave
                                I have been playing with my new rear parting tool. First off, parting a 100mm diameter cast iron bar (adaptor plate to mount a chuck on my rotary table). Yes, the tool overhang is a bit silly, but I wanted to know whether it would do it…
                                Next up, do I have the nerve to part a steel bar using the power feed (and a shorter tool overhang)?
                                #161641
                                  Posted by DrDave on 23/08/2014 22:08:19:
                                  Rather Scary … but very impressive.
                                  Bazyle
                                    @bazyle
                                    Painted house chimney cap. Pretty good view from 1200 ft asl. Not as good a job as I would like but running out of summer days. Wonder what age I will have to give up this sort of DIY caper – 75? Lit fire this evening – in August!
                                    #161648
                                    Muzzer
                                      @muzzer
                                      Looks like an HSS tool. Pretty impressive but I'm not sure I would have the balls to use power feed myself. I always use power feed with my indexable tool to get consistent (and sufficient) feed but usually during parting there are one or two "events" that would finish off an HSS tool, as the swarf decides which way to exit the work zone.
                                      Let us know how you get on!!
                                      Murray
                                      #161650
                                      mechman48
                                        @mechman48
                                        I wouldn't chance it it that overhang, plus you will end up with either a concave or convex surface on your parted off items, short overhang & rigidity is the name of the game, plus blade at right angles to the chuck
                                        George
                                        #161656
                                        Raymond Sanderson 2
                                          @raymondsanderson2
                                          Just got neighbours lawn mower going first time started since last summer. Bit of water in fuel tank from condensation even tho full. Throttle cable lever broken which didn't help much either, clean plug and adjusted.
                                          Beauty sunny spring day 19C.
                                          #161667
                                          Oompa Lumpa
                                            @oompalumpa34302
                                            Posted by Bazyle on 23/08/2014 22:42:30:
                                            As my roof is now dry-ish I will be climbing up later to remove the antennas that were blown cockeyed during the storms. The ones I told the last antenna installer to take down, but didn't. I will let you know how I get on.
                                            graham.
                                            #161670
                                            Clive Hartland
                                              @clivehartland94829
                                              What sort of flowers do you like Graham? Take care
                                              #161766
                                                While the rest of you have been getting in a muddle deciding if you are engineers or modellers I went out in the shed and completed the last few bits on this.
                                                Nemett NE15OT "OcelloT"
                                                #161767
                                                Roderick Jenkins
                                                  @roderickjenkins93242
                                                  Jason,
                                                  Very smart.
                                                  video?
                                                  Rod
                                                  #161769
                                                    Still need to make an engine mount and order an appropriate prop so will be a week or two before its time to dance.
                                                    #161779
                                                    Martin Walsh 1
                                                      @martinwalsh1
                                                      I have been machining some heavy duty angle iron from the scrap bin on the shaper
                                                      to make my own angle plates
                                                      Best Wishes Martin
