water leak repair without major surgery
Home › Forums › Beginners questions › water leak repair without major surgery
  • #77362
    Tony Martyr
      @tonymartyr14488
      I have discovered a small water leak from ‘somewhere’ in the bunker tank of my loco. This is after final painting and assembly so I really really don’t want to strip the whole assembly apart and have to a re-solder (even if I could locate the exact source) and re-paint.
      The problem is that this tank is totally enclosed and the only penetrations are the two stub pipes leading to the side-tanks and the breather tube running up through the coal bunker.
      It occurs to me that a concentrated dose of Halfords Radiator repair fluid might be the answer but I’m not sure if that needs to be heated to work – I could circulate hot water I suppose.
      Any bright ideas – I can’t be the only one in the ‘first loco’ build community to make this error?
      Tony
      #5736
      Tony Martyr
        @tonymartyr14488
        #77364
          Maybe one of the petrol tank sealing liquids would be more permanant than rad sealant. Pour it in, swill about and then leave the excass to drain, may need a funnel if the pipes are small.
          “Petseal” is one brand that springs to mind
          #77368
          ady
            @ady
            From one who used both eggs….and rad sealant in his old escort around about 1982.
            The trade off with rad sealant is a loss of heat transference.
            I used a couple of bottles and the car started overheating in traffic jams.
            So bear that in mind because it coats the entire system, and can result in quite a large loss of efficiency.
            #77373
            Gordon W
              @gordonw
              Rad sealent does need heating to work, at least the sort I’ve used. Would recomend tank sealent as used by M/C restorers.
              #77385
              Tony Martyr
                @tonymartyr14488
                Thanks Gordon – I found a possible source of a two-pot coating liquid for saving old petrol tanks by search M/C restoration sites. I have emailed for advice on my application and will advise on the success or otherwise.
                Tony
                #77460
                Tony Martyr
                  @tonymartyr14488
                  I have ordered a kit of ‘SureSeal’ from Tank Care Products and will advise on the results
