Dunno if it's occurred to you or not so I'll mention it.
You've ordered a mill and lathes with stands and various other goodies that will arrive together, hurrah! A man, probably with only a hand pallet mover, will move two large plywood boxes from the lorry on to your drive. Perhaps more than one box on each pallet, all strapped together with steel bands, and shrink-wrapped in plastic. My chap was happy to put them in my garage. Not going to be an issue in your case, but imagine what would happen if your workshop was a shed at the end of a muddy garden accessed via steps up and down from a cellar. A bog-standard delivery man is unlikely to help with that! A few people have reported stuff being delivered by grumpy gits who leave everything dumped on the pavement for you to sort out: not the usual experience thank goodness.
Here's the issue; the boxes alone will pretty much fill the space available in your garage. They're bigger than the lathe, mill and stands unpacked, and the bits take up considerably more floor space than when assembled. You will also have an engine crane to accommodate. Expect to have a temporary space crisis.
Unpacking and assembling will take time, especially if it's your first go and you don't have an assistant. If the stuff arrives late in the day, or you happen to be at work when it comes, you might find yourself pushed for both time and space. I unpacked on my drive, partly sheltered by my up and over garage door, just as well because it rained.
My lathe and mill were bought at different times. Neither was particularly difficult to deal with but I was tired by the time I'd finished each. Having to install two machines would have exhausted me without a break. (I'm an unfit retired office worker on the weedy side. A fit youngster would probably do the same without blinking. On the plus side I don't flap and dither in a crisis, on the downside I was inexperienced. Pays to be realistic about your limitations, if any!)
Anyway, not doom and gloom, but I suggest it's worth planning ahead, preparing and having a quick think about worst-case scenarios, particularly as you're tight for space:
- Where do you want them to put the boxes and in what order? My mill was straightforward because my garage was half empty and it arrived at 9am in good weather. The lathe arrived late in the afternoon: I had only just enough space to store it boxed in the garage overnight and unpacked it on the drive the following day. The lathe was OK, I got quite wet. If you mill is going to be set up at the rear of your workshop, it's probably best to position the box in front of the lathe.
- How you will see what you're doing in the event that you have to unpack after dark?
- What will you if it rains?
- Is it safe to leave boxes under a plastic sheet overnight on your drive, or will they attract crimbos?
- Will you have time to do unpack and setup alone if you can't get an assistant?
- Check you have room for the crane. The problem with mine is the legs splay widely and it won't turn in a tight space. Don't forget you need a lifting strap or strong rope as well.
I hope that doesn't sound too scary. As jobs go it's all perfectly do-able, but lack of space and small things can really slow you down. That can become stressful if you are short of time or gremlins strike. I have no doubt that you'll get it sorted – everyone else has!
