Warco GH 550
Warco GH 550
Home › Forums › Manual machine tools › Warco GH 550
  • #12925
    Vincent O Brien
      @vincentobrien84126
      #289739
      Vincent O Brien
        @vincentobrien84126
        Hi I was thinking of upgrading from my Boxford lathe to a Warco gh550 but as I live in Ireland it is hard to get my hands on one for closer inspection .Has anyone had any experience of this model.? As there does not seem to be much info about them out there.
        Thanks Vince
        #289804
          As it is a fairly new model that has only been available for a few months there is not going to be much mention of them on the net as not many people will have one.
          J
          #289810
          Vincent O Brien
            @vincentobrien84126
            That Jason that explains the lack of info
            Vince
            #289839
            MalcB
              @malcb52554
              When I sold my Boxford AUD not too long ago I was looking for a geared head lathe from either Warco or Chester. You cannot ignore the fact that the Chinese offer a lot of machine for not a lot of money.
              My choice narrowed down to picking between the Warco 1236 model and the Chester ( more local to me ) Crusader Deluxe. Both 300mm swing plus for gap bed removal. At the time both had similar price tags and had DRO's fitted. The Crusader Deluxe is more expensive now.
              I chose the Chester Crusader Deluxe, mainly because of location and which I almost bought.
              In the end I finished up with a late model Harrison M300 which my local machine tool dealer ( who I had dealt with for a long time ) had just got in stock and did me a great cash deal.
              My initial choices were based mainly on two factors, the gap bed removal, they had DRO fitted and decent bed length.
              When you look at the GH550 spec, it seems to be really quite light at 300kgs. I Think my Boxford was more than that on its very robust cabinet. Seems too light for its capacity.
              Personally if your funds would run to it and you could accomodate the size the 1236 would be my choice from the Warco stable. £700ish more gets you extra diameter and length capacity plus fitted DRO. Its also a more substantial machine and almost double the weight of the 550. I have seen both the Warco 1236 and the Crusader deluxe and they were very similar, however not actually seen the 550.
              #289854
              Bazyle
                @bazyle
                A few questions you need to ask Warco because their website is till so awful. I think the pages are put up by a secretary who has no idea what a lathe is and just keeps copying the last one.
                What is the chuck fitting – screw or camlock.
                Does it have a separate feed shaft as mentioned and if so how does the forward reverse lever on the picture work
                Does it have power cross feed as implied and if so how is it engaged.
                What are the actual speeds available.
                What are the knobs and levers on the front of the SC gearbox
                Which threads can be engaged without touching the changewheels
                Note the 4 jaw is the same size as the 3 jaw – traditionally a bigger one is supplied. Sneaky cost saving there.
                Is the manual as crap as the website.
                #289882
                BC Prof
                  @bcprof
                  Vincent
                  The majority of the queries raised are answered by simply reading the WARCO Info. Dedicated feed shaft for cross and longitudinal feeds ,flage mounted Chuck etc.
                  When I was considering one no details were on the site , simply that it was going to be introduced . I was concered abougt the chuck mounting and so rang Warco. I got an e mail giving full details within an hour
                  Brian C
                  #289884
                    Posted by Bazyle on 21/03/2017 13:28:04:
                    Why not just read the website Baz
                    It is flange fitting chuck
                    Has separate feed shaft
                    Has power cross feed
                    Usually no screws can be cut without altering from feed gear train
                    What screw cutting gearbox
                    Traditionally far eastern lathes tend to have same size chucks
                    #289933
                    Bazyle
                      @bazyle
                      My whole point was that I did read the website and pdf. The feed rod is mentioned BUT the picture does not show a power cross feed selector in the standard position on the apron but does show and label a fwd/rev lever next to a rod like the normal power selector so which is it.
                      Ok I missed the flange mount chuck because it was nowhere near the details of the chuck. The lathe just above on the Warco site the GH1236 has 160mm and 200 mm chucks.
                      There appear to be knobs on the front in the position that many other cheaper lathes have a QC gearbox, but the photo is too small to see. Some of the far eastern lathes now have a compromise part metric part imperial QCGB.
                      Unless the op needs a bigger swing specifically and often enough to make the cost worthwhile then a newer Boxford AUD would be a better bet.
                      #289935
                        This should show you how the feeds work and what the levers do. There is a lever facing the camera on the Warco photo bottom right of apron which makes it a bit hard to see.
                        Looks like you only get one feed ratio per gear train setup which could be a bit of a pain, the smaller 290, 280, 250 machines all have 3 speeds for any given gear train at the flick of one of teh front knobs, ditto thread pitches.
                        Edited By JasonB on 21/03/2017 19:09:24
                        #289944
                        Vincent O Brien
                          @vincentobrien84126
                          Thanks guys for your thoughts and opinions ,much appreciated.I think MalcB may be right it might be worth digging a bit deeper in the pockets and going for the bigger machine. I just posted here thinking their maybe a member who owns one and could give there opinion but they don't seem to be that popular a model so maybe that says it all.The cross slide travel is only 115 mm and that seems quiet short in my opinion but I am no expert.
                          Vince
                          #289973
                          Bazyle
                            @bazyle
                            Thanks for the video link Jason. Prima Dilna seem to have done a number of videos of Warco lathes and products that Warco should have done themselves.
