High voltage is the secret of efficient power transfer. As power cables are of fixed resistance (ohms), and waste in Watts is Amps² x Ohms, it pays to reduce cable losses by reducing amps and raising volts.
For example, when 1000W is to be transferred across a 1ohm cable:
- Transferring at 1V is a disaster because power dissipated in the cable would be 1000A*1000A*1Ω = 1MW. Far more energy is wasted heating the wire than reaches the other end.
- 10000V at 0.1A up the same wire is much better – same maths, but low current means only 0.01W is wasted heating the cable.
Increasing and decreasing 50Hz or 60Hz voltage is easily done with a transformer. Although robust devices, they're a little wasteful – between 2% and 5% of total power will be wasted as heat in the transformer. Nonetheless transformers are a good way of distributing high voltage AC power up to, say, 400km.
AC transmission smacks into a big problem over really long distances because power cables have reactance as well as ohmic resistance. When volts rise from zero during the AC cycle the cable charges up as a capacitor, and then discharges on the negative cycle. In the same way, the cable's self-inductance will store energy as magnetism, and convert it back to moving electrons on the opposite cycle. A power cable's resistance to AC is much higher than it's DC resistance. Cables will even radiate power like an antenna, dumping expensive energy into space. A very long cable connected to a 10000V 50Hz generator could be completely dead at the far end.
To avoid the problem interconnectors transfer power as high voltage DC. Cable capacitance and reactance have no effect on steady DC currents, so the wiring doesn't work against itself as AC does.
High voltage DC is converted to AC electronically, not mechanically. The electronics are more efficient than transformers, so even less energy is wasted. Interconnects are mostly used for long distance links between countries rather than internally because their installation is considerably more expensive than ordinary AC switch gear. Their financial purpose seems as important as providing supply – interconnects allow unwanted surplus electricity in one country to be sold cheap to another and vice versa. Flow direction varies with the market, rather than as a direct result of consumer activity.
