My watchmakers lathe is driven by a simple sewing machine "universal" motor.
I implemented a speed controller to replace the crude foot switch (3 speeds and off*) using a standard 400W lighting dimmer switch. It was very cheap from fleabay and works fine.
* The three speeds were full power, half wave rectified and half wave rectified with series resistor. The pedal applied power then shorted out (in sequence) the resistor then the diode.
Edited By Peter Cook 6 on 19/03/2021 13:13:30
