Posted by Andrew Tinsley on 25/06/2020 17:48:45:
An ejector is a simple case of a venturi effect , Simple applied Bernoulli theory. As Stephen says, there is little difference in performance (if any) between running an ejector on steam or compressed air.
Andrew.
Does Stephen say that? I see 'A vacuum ejector will work just fine on air, provided the design and manufacture of the ejector is okay.' It's a big 'provided' – are the design parameters for compressed air and steam really identical?
How about this quote:
While the ejector itself can be quite simple, specifying the optimum system to meet specific needs is not simple. Important parameters involved in ejector sizing and staging include pressure of motive gas, required discharge pressure, suction pressure and relative mass flow rates of motive fluid to suction fluid.
For instance, most ejectors use steam as the motive fluid. The quality of the motive steam affects the operation of the unit. The usual requirement is for dry, saturated high-pressure steam.
In operation, it is very important to maintain the design quality of steam. If the quality of the steam is low, suction pressure and capacity will decrease, especially in multistage designs.
Excessive steam superheat can also adversely affect the suction capacity of an ejector. It decreases the energy level ratio, and the increase in specific volume tends to choke the diffuser.
My point – if the quality of motive steam effects operation, wouldn't substituting compressed air be problematic too? But it is useful to know in practice ejectors can be tested on compressed air and at relatively low pressures.
If only it wasn't so hot I'd be delighted to read Andrew's simple explanation of ejectors using Venturi Effect and Bernoulli's Principle! As it is my brain can't cope with the Beano…
