If you have the latest version of Truview (may work in older versions) when you select plot the window will open and there is a selection of what to plot. If you choose window it will return you to the drawing for you to drag the mouse to create a window over what you want to plot.
Martin C
PS Forgot to add that you want to select fit to paper as well rather than print to scale.
Edited By Martin Connelly on 15/07/2022 18:24:04
