Hi Dean
In most respects (apart from the earliest models) the cast iron DB is nearly identical to the later and much more common aluminium or Zamac SL models. With the exception in some cases of the milling post and the headstock riser block, the tooling is identical. When it comes to cutting tools, 6mm may work without shimming, 1/4" HSS and 6mm carbide are fractionally too tall.
Unimat 3 toolposts and top slides are too high for the DB/SL, and the QCTPs sold for 7×12 mini lathes are too big (I tried my son's). Some of the members of the Unimat Yahoo group **LINK** (it is worth joining for the files section alone) have these US made QCTPs and appear very happy with them: **LINK**
Another option is to make additional toolposts (possibly from aluminium like the QCTPs) as they can then be exchanged without shimming by loosening a single cap head screw.
Edit: I just saw on another thread that you are in the US. In that case take a look at Toms Tool Store for Unimat spares http://www.tomstoolstore.com/
Edited By Brian G on 26/09/2017 10:07:17
