I thought it looked square so you would need to be able to remove that L to make use of being able to position it in those four positions.
Not sure what QCTP you have but some are drilled for a vertical index pin, you just drill 4 holes in the top of your block or even a ring of holes then the QCTP can be indexed to them simply by lifting the pin and it also helps stop rotation
