Years ago before plasma cutters and laser cutters which would have made life so easy I made a barrel for an early racing Motobecane 250. OHC with face cams.
This was an iron barrel but very close finned, I had no barrel, just pictures but the foundry was shy of trying to do one given the close fins.
I finished up cutting each fin out of sheet steel, probably 4mm and feathering the fins off with an angle grinder and sander.
Starting from the bottom I welded the fin onto a steel tube with a fair amount of weld which was then turned to a root fillet and faced off ready for the next fin to sit on. Second fin was welded into place and so on.
It was a pain feathering the fins off but it meant I could keep the unique outer shape of each fin very easily and there was a lot of variation in size from top to bottom both in size and outer shape.
The lower fins were more circular but the upper fins more square and they had the bevel tube inside the fins and not just a cutout.
When all welded, blasted and painted it looked awesome
