Trevithicks dredger engine
Home › Forums › Beginners questions › Trevithicks dredger engine
  • #45145
    ian kingdon
      @iankingdon14760
      D/S   Please, when are the remaining parts of the above articles likely to be on line as I have already started to construct this engine? thanks
      #4843
      ian kingdon
        @iankingdon14760
        constuction details
        #45146
        David Clark 13
          @davidclark13
          Hi there
          They are online.
          You should be able to find them by searching for them.
          regards David
          #45164
            Ken, the builder of the dredger that Richmond posted pictures of and that is at the top of this page told me that the valve gear as drawn does not work, so watch out before you cut any metal.
            He also suggests using Tufnol for the two rods not timber.
            Jason
            #45188
            David Clark 13
              @davidclark13
              Hi There
              Can someone post corrections to this article?
              regards David
              #46812
              Derek Weisgerber
                @derekweisgerber15154
                The main page states that all 14 parts have been uploaded yet I seem to see only 3. Am I in error or just missing
                 their location?
                #46814
                Redpiperbob
                  @redpiperbob16487
                  Hi Ian
                  Here are the links to the rest of the artilces but they are for subscribers only
                  #46815
                    The remaining parts are here but you need to be a subscriber to view, the alternative is to buy the back issues.
                    Jason
                    #46829
                    Laurence B
                      @laurenceb
                      I built a version of Tubal Cain’s Trevithick engine,modified to the 1808 locomotive ‘Catch Me Who Can’.I worked from the published drawings and didn’t have too many problems.I made steel connecting rods as the original loco may have had wrought iron rods rather than wooden ones as used on Trevithick’s earlier engines.It is a very interesting project to build.
                      #87656
                      keith english
                        @keithenglish89788
                        Where might I obtain the square headed bolts and nuts for this project,the source in the articles does not appear to stock them any longer.I note that the Guild of Model Wheelwrights are also looking for them.
                        #87658
                          Well you could make them, I picked up 6 meters of small stainless square bar for one of out members so he could make all the nuts & bolts for his 7 1/4G Locomotion.
                          I don't know of any UK suppliers that do square headed nuts & bolts but one of the German ME suppliers does them though I don't like the look of theirs too much, I'll did out a link in a while.
                          J
                          #87659
                            Square nuts here and here And I think its a case of silver soldering nuts to studding if you want bolts though making your own is likely to be easier.
                            J
                            #87666
                            keith english
                              @keithenglish89788
                              Thank you very much for the links Jason.I was "steeling" myself for making them.I will check out the nuts at least part of the job may be easier.As a matter of interest I obtained photocopies of the M.E. articles from Brunel engineering who also supply castings etc.
                              #87667
                                I bought the back issues a while ago with a mind to making it 50% bigger, should not be too hard as they are all described as fabricated.
                                There are a few pics of a nice one here, just a bit too much shinny brass for my likeing though.
                                J
                                #87668
                                keith english
                                  @keithenglish89788
                                  I must agree with you, a case of gilding the lilly!.I would like a working model and not a showcase job and the idea of scaling up is tempting.
                                  #87673
                                  David Clark 13
                                    @davidclark13
                                    Hi JasonB
                                    I have seen an all fabricated dredger engine and it ran nicely on compressed air.
                                    It was built at drawing size though.
                                    Diane is doing a Special magazine and it will include the drawings of the Trevithick Engine as a pull-out.
                                    More information in the next few weeks.
                                    regards David
                                    #87690
                                    Brian in OZ
                                      @brianinoz24148
                                      Well!! am darned if I can find/see them, the two links come up with
                                      "Error The article cannot be found."
                                      and the direct link comes up with
                                      "Search Results Articles 21 to 1 of 1" and the rest of the page is blank.
                                      Yes, I am a subscriber !
                                      Could someone help me ??
                                      Brian in OZ
                                      #87692
                                        Brian if you look at the dates of the early posts they are quite early on in the sites history. Since then a lot of the old stuff that was scanned and made available has been removed en-mass due to a few copyright issues. Not helped by newbie Keith resurecting an old thread rather than starting a new one
                                        David, are you going to publish just the drawings or text as well? if just drawings is there any chance of uploading the test again?
                                        J
                                        #87868
                                        Brian in OZ
                                          @brianinoz24148
                                          Thanks Jason, that had not occured to me.
                                          B in OZ
