I had this very problem with a brand new AC/DC Tig welder, I rang the Jasic Aftersales/Technical dept.
I was advised I needed to replace the 40A RCD(this RCD was already in the Consumer Unit) I had wired a 32Amp Isolator into, with at least a 32A MCB.
Never looked back, even use a 32A MCB for my 4kW VFD, with no problems at all.
This is just my experience of 10years, other peoples may vary.
Different problem! A brand-new welder is unlikely to be faulty, and the after-sales dept would know why it’s likely to upset a Residual Current Breaker and why a circuit breaker is appropriate.
Circuit breakers aren’t a general solution though! Anyone worried about safety should insist on an RCB because their sensitivity makes electrocution less likely! RCBs can’t be applied universally though. Some equipments, like filtered power electronics, legitimately leak enough current to earth to be mistaken for a fault. Equipments that leak to earth are normally built to minimise the risk, double insulated inside and so forth.
ell81 is playing a different game. He’s interested in secondhand motors, and some of those he’s asked about here were in poor condition, electrically risky. Flaky, burnt, or damp insulation. Loose wires, lethal earth faults and shorts are all possible. And the motors are removed from the equipment that originally protected their wiring and the operator. Hence he’s been recommended to test with a multimeter and Megger before connecting to the mains. In this application, a motor that pops an RCB is almost certainly faulty, and it’s important to make it safe asap. So a circuit breaker that hides problems is a bad move, especially when a sensitive RCB might save his life if a test goes wrong!
When Bernhard uses his equipment, the electrical lions are safely caged. Not so when ell81 fault-finds motors; he’s inside the cage busily poking big-cats with a sharp stick! An RCB might save his life.
Working on live equipment is special. Many precautions: ideally don’t! Avoid concrete floors, keep one hand in a pocket, only use the right gear, and assume everything is live, even when absolutely certain it’s dead. Don’t work alone, and make sure they know what to do when you’re on fire and stuck to an electrode. Test everything and trust nothing and nobody… Live work needs a lot of thought, and a risk assessment, and despite that professionals still get killed and burnt.
