As for the lathe not being level, some of you might have seen the one I had on the SMEE stand at Ally Pally, which used a digital level. The advantage being that you could set “zero” on, say, the top slide and then “level” the tool height. These devices clearly work best on quick change tool posts, where the height is easily adjusted by screw, rather than standard ones where shims are needed. I made my digital one to see if the idea worked and it maybe a toy, but where would we be without our little playthings?
As for “anodized”, well it depends on the style of anodizing, doesn’t it. There is anodizing which is mostly decorative, pretty colours, and then there is the hard variety which is almost impossible to even scratch. I do suspect that the items in question are merely the pretty type, though.
An arch sceptic and cynic,
chriStephens
