Hi All,
Beginner here, where to start?
I have a Tich, which I got after its owner sadly passed away. Photos attached, it is in a reasonably advanced stage of construction. The center eccentric and axle pump are not there and the cylinder front covers are required. There are some odds and ends which are also needed. There is a cab with roof and one side tank and some new parts as well.
I have an ML7, which I'm currently brining back to life and cleaned. I also have a Juliet castings set, but the Tich is much further on and I would like to finish this first. Pic below:
Cab and Tank
The question is, where do I start?!!
I would like to take it apart to clean off the surface rust, but the parts are all push fitted, how do I take them apart? For example the wheels are pushed on the axles, do you use heat to take them off?
Should I buy a boiler, or boiler kit or self source the parts or copper….?
How should I proceed?
Thanks All
