Threading a bar for 6ba
Home Forums Beginners questions Threading a bar for 6ba
  • #395188
    Former Member
      @formermember19781
      Former Member
        @formermember19781
        #395192
        Howard Lewis
          @howardlewis46836
          The Model Engineer's Handbook, Third Edition, by "Tubal Cain" gives the top diameter of 6 BA as 0.1102" or 2.80 mm, so you should be OK with 0.110"
          #395195
          Clive Brown 1
            @clivebrown1
            Bill,
            Have you considered buying 6BA threaded rod? Rather less hassle than DIY if you need any significant length.
            Lots of hits on google/Ebay in several materials.
            #395198
              That's right althouigh slightly undersize won't do any harm.
              I doubt you will be able to buy those sizes off the shelf.
              The Novice Engineer
                @thenoviceengineer
                #395204
                not done it yet
                  @notdoneityet
                  I expect you can use any size above the minimum, but if long lengths you will need a traveling steady to turn the rod to size. Are you single pointing or running a die down the rod? As above, buying threaded rod may be easier, but obviously several choices. But threaded rod is expensive if you only need the threads on each end.
                  #395205
                    EKP sell 7/64" which will take 6BA quite nicely.
                    Alternatively can you substitute 3.0mm rod and thread M3
                    #395212
                    Former Member
                      @formermember19781
                      #395216
                      Ian Skeldon 2
                        @ianskeldon2
                        Firstly my apologies is this post is considered to be hi-jacking the original thread (there's a pun in there somewhere).
                        What is considered to be the best way to create very small diameter threads ( 1mm for instance) both internal and external, can you buy taps and dies in that sort of size?
                        Thanks,
                        Ian
                        #395218
                        Benjamin Day
                          @benjaminday94198
                          Ian, search watchmaker die plate. Several size dies are all on one plate, they usually come with the silly tiny taps too. Hope this helps!
                          #395226
                          IanT
                            @iant
                            Hi Ian S2
                            Surprisingly (at least I was surprised) Machine Mart sell a set of taps and dies that range from 1mm to 2.5mm. I've only used mine on brass (and will not use them on ferrous at all) but they seem OK. Usual cautions – you need to guide the tool – both the taps and dies in these sizes – especially the small ones. I've just checked and they are currently £38.39 a set
                            Probably not top quality at that price but for occasional (and careful) use they were the best option for my needs.
                            IanT
                            #395227
                            Nick Clarke 3
                              @nickclarke3
                              Posted by Ian Skeldon 2 on 07/02/2019 19:25:43:
                              Thanks,
                              Ian
                              I have the set that IanT suggested and second his views.
                              Have a look at Tracy Tools website, or if you are at Doncaster Show pick up one of their catalogues. – usual disclaimer – just a satisfied customer – other suppliers are available etc etc
                              #395342
                              Ian Skeldon 2
                                @ianskeldon2
                                Thank you Benjamin, IanT and Nick, I will check out both of those suggestions.
                                Ian
                                #395425
                                Chris Trice
                                  @christrice43267
                                  #395426
                                  Chris Trice
                                    @christrice43267
