Threaded Bar Rod Studding
Home › Forums › General Questions › Threaded Bar Rod Studding
  • #91905
    Kevin Bennett
      @kevinbennett25223
      hi help needed for a supplier in the UK for 9/16 BSW studding i have spent the last hour on the Internet looking with no luck.
      it is to repair 2 sash clamps and it has to be 9/16 BSW
      can someone point me in the right direction
      thanks Kevin
      #22114
      Kevin Bennett
        @kevinbennett25223
        #91909
        Keith Long
          @keithlong89920
          Hi Kevin
          Good luck with your search, but you should be aware that 50 years ago 9/16 BSW was listed as a non preferred size to be avoided where possible. (Kempes Engineers Handbook 1965 edition).
          If you really want to repair the clamps you might be better off getting a die and cutting your own on some suitable rod!
          Keith
          #91911
          V8Eng
            @v8eng
            Might be worth asking these people, they supply all sorts of hard to get fixings etc.
            Regards.
            #91912
            NJH
              @njh
              Hi Kevin
              If you decide to go along the D-I-Y route you can find the die here
              Not too cheap an option –  although for a one off job the carbon steel version should be OK.
              regards
              Norman
              Edited By NJH on 01/06/2012 19:42:57
              #91919
              Les Jones 1
                @lesjones1
                Hi kevin,
                The only listing I can find for 9/16" BSW is in stainless steel and the company does not give a price. This is the company.
                Les.
                #91924
                  Is it definately Whitworth form as UNC is also 12tpi at that diameter.
                  J
                  #91925
                  robert ramage
                    @robertramage25020
                    Hi Kevin. what sort of length are you after?
                    #91926
                    Kevin Bennett
                      @kevinbennett25223
                      yes it is definitely BSW checked several times i am also looking at 14mm as well.
                       2 off  at   8" long
                      Ty Kevin
                      Edited By Kevin Bennett on 01/06/2012 22:14:42
                      #91936
                      Martin W
                        @martinw
                        Hi
                        It might be worth contacting GWR Fasteners on Ebay as they stock a fairly large range of BZP studding in BSW sizes. While I didn't see 9/16 size they may be able to locate some or point you in the right direction.
                        Cheers
                        Martin
                        PS. On closer reading of the Ebay posts for studding GWR Fasteners suggest that you email them if it is not listed.
                        Edited By Martin W on 02/06/2012 00:06:55
                        #91940
                          At 8" long can you not screwcut it?
                          J
                          #91956
                          Tony Pratt 1
                            @tonypratt1
                            Hi, 9/16" UNC will do the job if you can obtain it!
                            Tony
                            #91958
                            KWIL
                              @kwil
                              Search for BSW All Thread, gives another supplier
                              http://www.archerdale.com/buy-tools-fasteners.php?WEBYEP_DI=13
                              #92016
                              Kevin Bennett
                                @kevinbennett25223
                                thanks for all the help and advice i have a few thing to think about.
                                TY Kevin
