What you call "waves" are the form of each thread.
In the case of Whitworth form threads, (BSW, BSF, BSP and BSB – British Standard Brass ) the angle of the thread is 55 degrees.
The Depth of the thread is related to the pitch, by a formula, which need not concern you as a user.
Thus, a 1/4 BSW is 20 tpi, with a depth of 0.0320", whereas a 3/8 BSF is 20 tpi and the depth is still 0.0320".
If it were a 1/4 BSF thread, it would be 26 tpi with a depth of 0.0246". So for a given size, the finer thread would have a shallower depth.
The 40 tpi Model Engineer series are Whit form, but have a thread depth of only 0.016"
If you do not have one, invest in a set of Zeus Charts. You will find them invaluable. I still use the ones that I bought as an Apprentice, back in 1958!
This lists the details of many sorts of threads, giving tpi, pitch, depth and core diameter, and in a separate table the correct tapping drill and clearance drill to be used.
Additionally, it includes allowances for when bending sheet metal, and Trigonometry tables, which you may also find useful
Find a Model Engineering Club near you, and join. You will then be likely to obtain actual hands on experience, with other more knowledgeable folk.
Fat Fingers strike again!
Edited By Howard Lewis on 28/08/2019 18:29:29
