This Weeks Mystery Tool?
Home › Forums › Manual machine tools › This Weeks Mystery Tool?
Viewing 25 posts - 1 through 25 (of 33 total)
  • #340389
    Martin King 2
      @martinking2
      Hi all,
      This weeks oddity from a tool lot:
      Seem very well made and has been hardened and ground. Perhaps not a tool but a part of something? Any thoughts please?
      Cheers, Martin
      #13134
      Martin King 2
        @martinking2
        #340400
        mechman48
          @mechman48
          looks like item off something… ratchet, release mechanism, foot operated lever off a brake press of some type, over speed trip mechanism from a turbine… to guess a few ?
          George.
          #340414
          Marischal Ellis
            @marischalellis28661
            Hammer head for several applications in certain order. Oops
            #340415
            not done it yet
              @notdoneityet
              Foot operated process switch of some sort.
              #340422
              Mick B1
                @mickb1
                Trip lever out of a machine tool or artillery piece.
                #340429
                Roderick Jenkins
                  @roderickjenkins93242
                  The long arm is reminiscent of an iron for holding down a (wood) plane blade, possibly pivoted around the hole and tensioned by a jacking screw under the short arm. Nothing like it in Salaman though.
                  Rod
                  #340430
                  Rik Shaw
                    @rikshaw
                    "Ratchet" stop with handle for engaging / disengaging from toothed gear. Very large clock??
                    Rik
                    (Martin – you will need all your marketing talents to aim this in the right direction – "paperweight" is my best idea.)
                    #340437
                    Martin King 2
                      @martinking2
                      Hi All,
                      I think I get the general gist here laugh
                      Clearly I have not found a hitherto unknown masterpiece of English planemaking by NORRIS. frown
                      I have to ask as sometimes the unkown to me is blindingly obvious to someone on here and the item now destined for the scrap box may have been of use to someone and thus possibly of some value.
                      This may be a good time to ask if it really is OK for me to post like this or do people feel that I am wasting time and bandwidth. I fully own up to the fact that I buy and sell items and am therefore guilty using this forums knowledge resource to further my own interests at times.
                      If it is felt generally that this is not on please let me know.
                      I do read the build threads on here voraciously and glean all I can to improve my own machining skills which I enjoy immensley.
                      Cheers all, Martin
                      #340440
                      Journeyman
                        @journeyman
                        Posted by Martin King 2 on 08/02/2018 16:52:42:
                        Cheers all, Martin
                        I for one think it is quite interesting to see some of your finds. Amazing what people throw out in boxes!
                        As to the item above I would go for a machine part, some kind of trip mechanism where a cam runs on the end of the longer arm. Almost like a bit of a Corliss engine valve gear.
                          Keep it up, Martin
                          You are open about what you're doing, and the puzzles are often interesting.
                          Rik Shaw
                            @rikshaw
                            "If it is felt generally that this is not on please let me know."
                            Keep going Martin – 'tis nice to hear from darkest Dorset!
                            Rik
                            #340468
                            I.M. OUTAHERE
                              @i-m-outahere
                              Sure beats the "What lathe / mill/ drill or any other common workshop tool should i buy " threads that pop up on a mothly basis !
                              #340497
                              Martin King 2
                                @martinking2
                                Thanks guys, will keep digging around then! smiley
                                Martin
                                #340506
                                Clive Hartland
                                  @clivehartland94829
                                  The item is reminiscent of a sear or part of an interupptor mechanism. most likely from a machine gun?
                                  #340512
                                  Jon Cameron
                                    @joncameron26580
                                    Maybe it's a fancy scraper cheeky
                                    To me it looks almost like a foot pedal though it's too small the large flat been a stop under floor level. The opposite flat acting the master cylinder. The fancy shaped bit at the top to hold the rubber pedal.
                                    #340562
                                    Ian S C
                                      @iansc
                                      My guess, the ratchet pawl for a shaper auto feed.
                                      Ian S C
                                      #340577
                                      David Standing 1
                                        @davidstanding1
                                        I like the brain teasers too. It often comes down to digging deeper and quicker in Google than MichaelG laugh
                                        #340586
                                        Tim Stevens
                                          @timstevens64731
                                          Might it be part of a 'hit and miss' governor mechanism, as found on stationary engines (etc)?
                                          Cheers, Tim
                                          #340589
                                          norman royds 2
                                            @normanroyds2
                                            I it think it some thing part of printing machine norm
                                            #340608
                                              Posted by David Standing 1 on 09/02/2018 12:11:41:
                                              That sort of 'back-handed compliment' gets rather tedious, David.
                                              I'll be grateful if you would desist.
                                              David Standing 1
                                                @davidstanding1
                                                Posted by Michael Gilligan on 09/02/2018 14:53:06:
                                                Michael
                                                There was nothing back handed in my compliment, I respect you too much for that.
                                                I think you may have confused me with someone that uses silly nicknames (and I have never referred to you in any way but your correct name).
                                                If my comments are misleading, then I shall just desist from answering altogether, as I don't have the time or inclination to get involved in silly spats on this forum.
                                                Kind regards
                                                David
                                                #340657
                                                mark costello 1
                                                  @markcostello1
                                                  Don't We all use the Forums resources to further Our interests? Thought I was doing something wrong for a minute.
                                                  #340660
                                                    Posted by mark costello 1 on 09/02/2018 20:20:04:
                                                    Indeed, Mark … I think we do.
                                                    But I believe that Martin was doing the decent thing, and asking whether anyone objected, because he tends to ask questions that further his commercial interests.
                                                    Edited By Michael Gilligan on 09/02/2018 20:35:18
                                                    #340676
                                                    Martin King 2
                                                      @martinking2
                                                      Thanks Michael,
                                                      That was exactly my point.
                                                      Regards, Martin
