On the ST 9 that I refurbished, I used ball bearings, I heated them red for a few minutes, then when cool popped them in the lathe and drilled them, pushed the arm through and riveted it over. I think they may have been 1/2", just a bit larger than the drawing size.
If you go to the garden shop, there is a good chance you may be able to get bronze, or stainless balls as spares for garden spray pumps, there are a number of sizes, 3/16"/ 5 mm, and 1/4"/ 6 mm are two that I'v seen. Ian S C
Edited By Ian S C on 03/05/2014 11:44:27
