The Function of Piston Rings
Home › Forums › Model Engineer. › The Function of Piston Rings
Viewing 2 posts - 1 through 2 (of 2 total)
  • #215632
    Kiwi Bloke
      @kiwibloke62605
      OK, there's more than one way to skin a cat…
      This is a complex subject and many methods of making rings have been published. Some are very much better than others. The method of manufacture described is designed to produce a circular outer surface, but what about the inner surface? Does the resulting ring produce a constant radial force on the bore (as it should), all around its circumference?
      I'd guess that most readers are already aware of Prof. Chaddock's seminal writings in ME about piston rings. A good overview of this complex subject can be found here: **LINK** and it's well worth searching out the source documents to which the author refers.
      #37692
      Kiwi Bloke
        @kiwibloke62605
      Home › Forums › Model Engineer. › Topics
