Posted by Michael Gilligan on 24/11/2017 15:03:11:
Posted by Hopper on 24/11/2017 13:55:51:
While we are on the subject, the use of square brackets is usually limited to enclosing words added by someone other than the original writer, usually an editor. Round brackets should be used to set off parenthetical comments by the original writer, or to set off information not essential to the rest of the sentence. Using square brackets in place of round results in turgid obsfuceration again.
Whilst we are on the subject …
In my line of work; square brackets are used inter alia to enclose explanatory text, and to indicate where optional text needs to be inserted.
On a purely practical level, though … On this forum they mitigate the risk of introducing "accidental smileys".
Suggestion: You write you posts your way, and let me write mine my way.
P.S.
"Round brackets should be used to set off parenthetical comments" might well be nominated for tautology of the week.
Not sure what line of work you're in but the rest of us are not, so best to use the normal conventions so your audience can understand what the heck you are on about. To avoid smileys, simply add a space.
And perhaps we should just let the scientists write their posts their way, and we ours? I think if we are going to criticize someone else's use of language, we should get our own right while doing so.
No tautology in setting off a parenthetical comment. Quite justified for clarity in the context.
And "inter alia"? Do you mean amongst other things? Or are you just engaging in turgid obsfuceration again?
Edited By Hopper on 25/11/2017 00:58:26
