Thanks, again, for all the input.
I like the idea of making it from scratch – I’ll investigate the College Engineering lead, (that’s pronounced “leed”, not “led”!!) although I think I’d have to have it delivered to the UK and get someone without a hernia to bring it over!
The reason for wanting a cross-slide with tee-slots is, well, because they’re not there now! In addition, I’m making my own, modified, version of the “Bedair ball-turner”, which I will obviously need to mount on the cross-slide. Other tools which attach there also would be easier to mount with tee-slots, for example my rotary table.
My dovetail is 11.3mm deep x 60mm at its widest and the cross-slide itself is 25mm deep, leaving insufficient room for tee-slots. It’s not wide enough for longitudinal ones, either, at only 110mm wide.
Yes, I would lose some centre to cross-slide distance, but I could always replace the original if things were that critical.
Anyway, back out to the workshop, I’ve got swarf to make!
