taper pins
taper pins
Home › Forums › General Questions › taper pins
  • #23036
    Dougie Swan
      @dougieswan43463
      #138805
      Dougie Swan
        @dougieswan43463
        Can anybody tell me where I can find some taper pins with the large end approx 3/16
        Also how are taper pins categorized into different sizes
        Thanks
        Dougie
        #138807
          Try EKP, they also have reamers to suit
          Categorized by nominal dia which is the large end x length. Imperial are 1:48 taper, metric 1:50
          #138811
          Dougie Swan
            @dougieswan43463
            Thanks Jason
            Just what I needed
            Dougie
            #138819
            Anonymous
              Dougie: Beware, the old BS standard for imperial taper pins is as Jason says, the nominal diameter is the large end. However, the newer DIN standards for metric taper pins quote the nominal diameter at the small end.
