sweetpea cylinders
sweetpea cylinders
Home Forums Beginners questions sweetpea cylinders
  • #131974
    old wrinkly
      @oldwrinkly
      Hi is it possible to use a set of unmachined castings from a simplex on a sweetpea of the same size ????
      old wrinkly
        @oldwrinkly
        #131975
        old wrinkly
          @oldwrinkly
          sorry still new to this forum thing the castings are for the cylinders any suggestions would be greatfully recived dek
          #131997
          Another JohnS
            @anotherjohns
            Dek;
            Not having the drawings, but having 1 Sweet Pea, and 2 Simplexes (both variations) in the club, I'd think that the 5" Simplex Cylinders would probably do for the 3-1/2" gauge version of Sweet Pea; the relative sizes of locomotives lead me to think that.
            Maybe others with both sets of plans will chime in?
            Another JohnS.
            #132022
            old wrinkly
              @oldwrinkly
              Hi john I believe the cylinder bores are the same, this is what made me ask the question, and that I can get hold of the cyl set at a good price. Dek
              #132029
              FMES
                @fmes
                Hi, there are a couple of differences, the material being one, the 'Pea' cylinders are normally cast iron and simplex are gunmetal, the bores are the same, but simplex stroke is 1/8th longer (should be adaptable), the only awkward thing I can see is that the steam inlet enters the side of the valve chest on Simplex, through the frames, whereas the Pea inlet goes into the top of the valve chest between the cover and the frames.
                Whether there is enough meat on the Valve chest to allow for this inlet fitting on the Simplex cylinders I'm not sure, but you may be able to modify the chest cover to take the steam pipe.
                One thing I noticed with mine is that it develops a very high vacuum on the overun with the regulator shut so I fitted snifting valves to the dead center of the chest cover, these if required could always be offset.
                Hope this is of help
                Lofty
                #132083
                old wrinkly
                  @oldwrinkly
                  thanks lofty, I will look into what you have said, and thanks for the tip, will make a note for future use, dek
                  Edited By old wrinkly on 08/10/2013 22:42:03
